TBB Ping Graphs
- News & Announcements
- Community Announcements
- Re: TBB Ping Graphs
Re: TBB Ping Graphs
18-02-2015 2:04 PM
Re: TBB Ping Graphs
18-02-2015 3:28 PM
Re: TBB Ping Graphs
18-02-2015 3:32 PM
Would that imply a different IP address? In which case one would expect the graphs to be all red... unless the ping attempts report unroutable maybe?
Kevin
Re: TBB Ping Graphs
18-02-2015 3:40 PM
Re: TBB Ping Graphs
18-02-2015 3:45 PM
It was the ones like mikehiow that need removing.
Solid red ones probably need checking to make sure the user is on fixed IP.
Re: TBB Ping Graphs
20-02-2015 8:45 PM
Quote from: Townman And there will be a load more coming up red as the new static IP addresses become active...
new static ip addresses? plusnet changing static ips around?
Re: TBB Ping Graphs
20-02-2015 9:13 PM
Quote Hello Mr Kevin,
Important Information about your Plusnet Broadband Account
We're making a small change to your broadband account during the week beginning 16th February. This will give you a new static IP address*. It is likely this will not affect you and you will not need to do anything further unless you run your own website, email server or use a virtual private network (VPN).
What's going happen?
During the week beginning 16th February we will change the static IP address we currently give you to a different one. We will send you an email confirming what the new static IP address is once we've made the change and you'll then begin using the new address the next time you disconnect and reconnect to the Internet or reboot your router.
I cannot assert that this is ALL static IP address allocations and it would be folly to surmise that it is a global change.
Kevin
Re: TBB Ping Graphs
20-02-2015 9:16 PM
Re: TBB Ping Graphs
28-02-2015 2:40 PM
Fibre Unlimited, Static IP
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/4611a2d74ecde48393a3d188b96395e6.html"><img alt="My Broadband Ping - Plusnet Unlimited Fibre" src="http://www.thinkbroadband.com/ping/share-large/4611a2d74ecde48393a3d188b96395e6.png" /></a>
Re: TBB Ping Graphs
10-03-2015 10:05 AM
Quote from: jelv Some housekeeping is required - there's a number of graphs which are coming up blank because the monitor has been deleted from TBB.
anyone going to catch these up? mine's still showing the old one.
Re: TBB Ping Graphs
11-03-2015 9:48 AM
21CN Unlimited
Re: TBB Ping Graphs
11-03-2015 6:33 PM
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/0c6a63c8ad9b0320e01cec419ec31745.html"><img alt="My Broadband Ping - RPM - IPv4" src="http://www.thinkbroadband.com/ping/share-large/0c6a63c8ad9b0320e01cec419ec31745.png" /></a>
Re: TBB Ping Graphs
19-03-2015 4:00 PM
Fibre Unlimited
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/98764ab467fba38a14ddb0e7d38d77ae.html"><img alt="My Broadband Ping - My Plusnet Fibre IPv4" src="http://www.thinkbroadband.com/ping/share-large/98764ab467fba38a14ddb0e7d38d77ae.png" /></a>
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/5d6b12d1cf1ea723232285795b053156.html"><img alt="My Broadband Ping - My Plusnet Fibre IPv6" src="http://www.thinkbroadband.com/ping/share-large/5d6b12d1cf1ea723232285795b053156.png" /></a>
Re: TBB Ping Graphs
19-04-2015 1:55 PM
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/c6461862e24c068c7acb52ca61ce7b11.html"><img alt="My Broadband Ping - Plusnet Fibre 40/20" src="http://www.thinkbroadband.com/ping/share-large/c6461862e24c068c7acb52ca61ce7b11.png" /></a>
Re: TBB Ping Graphs
27-04-2015 11:52 AM
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/36d1630f5d53bc9121f2cb33097c8ef0.html"><img alt="My Broadband Ping - Home" src="http://www.thinkbroadband.com/ping/share-large/36d1630f5d53bc9121f2cb33097c8ef0.png" /></
