Do you mean
TBB Ping Graphs
Re: TBB Ping Graphs
Mcted wow what are you doing  Huh
Premium 120gb
nothing really going on here except seems to be a fair amount of packet loss  Undecided
Re: TBB Ping Graphs
Quote from: rammie
I wish I knew.
Community Gaffer Community Gaffer
Fixes: 101
Re: TBB Ping Graphs
McTed: There's quite a bit of upload happening on your line, I'm wondering if that's the cause of the crazy graph.
 Chris Parr
Re: TBB Ping Graphs
Really? I'll test again with nothing plugged in.
Re: TBB Ping Graphs
Could plusnet please add my live monitor onto this page under Unlimited Fibre: http://community.plus.net/ping-graphs/
Thanks, as I am also on static IP with Unlimited Fibre Live Monitor here: http://www.thinkbroadband.com/ping/share/978c464247e9345475951e6796ff32c1.html
Re: TBB Ping Graphs
you must be downloading a lot?  Cheesy
Re: TBB Ping Graphs
Unlimited FTTC PlusNet speed at 47.2 Mb
My Broadband Ping
Re: TBB Ping Graphs
Houston... I think we have a problem.  Looks like the opening titles to 8 out of 10 cats :/...
Re: TBB Ping Graphs
Here's mine
Re: TBB Ping Graphs
Maxadsl 20cn ipstream (or whatever its called). We're one of the lucky ones around here. IPprofile about 7Mbps with exchange about a couple of miles away.
Fixes: 101
Re: TBB Ping Graphs
I'll go through this thread and gather the new ones/check for updates on the old ones later this week.
 Chris Parr
Re: TBB Ping Graphs
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/6f1c5eafdc717863791b5d787acac2d6.html"><img alt="My Broadband Ping - Graph 1" src="http://www.thinkbroadband.com/ping/share-large/6f1c5eafdc717863791b5d787acac2d6.png" /></a>
hi can anyone tidy that up to display the graph please
Edit: looking back , it seems there is a big increase in latency between 7-8pm and 11pm, noticeably worse last 2 days.  i usually game in this time and put it down to that , but ive not been gaming since sunday afternoon, so i think it might be worth looking at.
Re: TBB Ping Graphs
I certainly used to see some blue and yellow in the evening period but recently that seems to have largely gone for me. I'm assuming a capacity issue somewhere got fixed.
I think the yellow spikes may be the SamKnows box and ISPA speed tester doing tests
Re: TBB Ping Graphs
My monitor needs to be shifted from the "Extra Fibre" section to the "Unlimited Fibre" section.
Ta
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: TBB Ping Graphs
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/b7cd90e68fe69ddb054565892acfffcc.html"><img alt="My Broadband Ping - Jaggies" src="http://www.thinkbroadband.com/ping/share-large/b7cd90e68fe69ddb054565892acfffcc.png" /></a>
I'm on 21CN Unlimited ADSL.
