TBB Ping Graphs
Re: TBB Ping Graphs
No loss in connection but I had a ping change at 12pm yesterday?  I thought a ping change could only happen with a reconnection and getting a new gateway.  Or is the BT system changing other settings on the fly?
edit: 12pm and just lost PPP connection but not sync, seems to be a trend
edit: added the live graph by mistake
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Ronski
Re: TBB Ping Graphs
Quote from: Chris
I'll pick any that aren't on the page up soon and get them on there.
You've not added the graphs yet.
Fixes: 10
Re: TBB Ping Graphs
You've got some very interesting step changes in minimum latency on your graph! Have you had any resyncs?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: TBB Ping Graphs
@jelv me? other than 12pm yesterday no, the 2.30pm change yesterday was with no lost PPP connection or sync with the exchange.  I had a fault ticket open to get my SNR set to the default of 6 after a landline fault was fixed, so wondering if there is some background monitoring that is changing it on the fly.
Now waiting for 12pm today to see if something happens, if it does then there is some smoke and time to find the fire as that will be 3 days in a row.
Fixes: 10
Re: TBB Ping Graphs
Not you, I was responding to the immediately previous post by Ronski. Here's his graph - you'll see what I mean. Two of the changes may be associated with resyncs but that last doesn't seem to be.
Ronski
Re: TBB Ping Graphs
I have on going problems with many resyncs ,  take look here for some more graphs.
I'm making sure everything is ok my end before I get PN involved
Edit: The one at 13:00 yesterday was where I swapped the modem for another, but I'm still having problems so will try a different modem cable as thats the only thing left to try.
Re: TBB Ping Graphs
You can add our graph too. We're on the (new) Fibre Extra @80/20
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/e4c622cd3a788c9c6c78fbb16ea3c24c.html"><img alt="My Broadband Ping - HG FTTC" src="http://www.thinkbroadband.com/ping/share-large/e4c622cd3a788c9c6c78fbb16ea3c24c.png" /></a>
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Fixes: 168
Re: TBB Ping Graphs
Quote from: Ronski
Quote from: Chris
Sorry, I was on leave last week. Will get them updated asap.
 Chris Parr
 Plusnet Staff
Fixes: 168
Re: TBB Ping Graphs
Quote from: WWWombat
Quote from: Ronski
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/fce24b487f52421f5df78da08e296b94.html"><img alt="My Broadband Ping - Extra Fibre Home" src="http://www.thinkbroadband.com/ping/share-large/fce24b487f52421f5df78da08e296b94.png" /></a>
Quote from: rudd42
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/abc235376e52133606a0a25d5877275b.html"><img alt="My Broadband Ping - Home" src="http://www.thinkbroadband.com/ping/share-large/abc235376e52133606a0a25d5877275b.png" /></a>
Quote from: the_norris
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/3b70007f06cb394613515f726e78f16b.html"><img alt="My Broadband Ping - Home" src="http://www.thinkbroadband.com/ping/share-large/3b70007f06cb394613515f726e78f16b.png" /></a>
All added.
 Chris Parr
 Plusnet Staff
Fixes: 168
Re: TBB Ping Graphs
Right, I think I've added everyone that has a valid graph.
For those that have been added it would be good to get a short sentence about how you use your connection, that will help us pinpoint anything out of the ordinary.
For example
[quote=Chris]Connection is generally used for gaming and streaming in the evening, with downloading for a couple of hours shortly after midnight occasionally. Very little daytime weekday usage.
 Chris Parr
 Plusnet Staff
Fixes: 10
Re: TBB Ping Graphs
OK, so what have you got against ID and myself that we don't warrant links to Extra 21CN with Pro add-on or Extra 20CN at the top of the page?
Fixes: 168
Re: TBB Ping Graphs
No comment 😕
 Chris Parr
 Plusnet Staff
Fixes: 168
Re: TBB Ping Graphs
I'd actually created the anchor tags when I did all the others, for some reason had just missed them from the menu. Done now.
 Chris Parr
 Plusnet Staff
Fixes: 10
Re: TBB Ping Graphs
[quote=jelv]Browsing and emails plus a VPN connection running remote desktop (no file transfers) for extended periods. Occasional iPlayer usage but no other regular large downloads.
Fixes: 742
Re: TBB Ping Graphs
Mine:
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/9144a3997781d29ef7685536d3280dd3.html"><img alt="My Broadband Ping - HomeExtraFibre" src="http://www.thinkbroadband.com/ping/share-large/9144a3997781d29ef7685536d3280dd3.png" /></a>
