TBB Ping Graphs
- News & Announcements
- Community Announcements
- Re: TBB Ping Graphs
Re: TBB Ping Graphs
04-08-2012 7:58 PM
Ex-Broadband Service Manager
Re: TBB Ping Graphs
04-08-2012 10:35 PM
Jelv is right.. I'm not toooooo far away from that thar Londinium.
Re: TBB Ping Graphs
09-08-2012 5:28 PM
http://www.thinkbroadband.com/ping/share/82c8329dc40035634a21b8599c3c1154.html
Only just set it up, so it's empty right now.
Re: TBB Ping Graphs
09-08-2012 5:32 PM
You could always reset my usage? For scientific purposes, of course ::).
Re: TBB Ping Graphs
09-08-2012 8:41 PM
If you have one of the PN supplied Thomson routers this has to be done via telnet, however there is a guide to this here.
Alex
Re: TBB Ping Graphs
10-08-2012 2:04 PM
Quote from: houlton23 Looks to me like your router isn't responding to ICMP (ping) packets on it's WAN port. You need to look on your router's admin interface for the option to 'respond to ping on wan interface' or similar.
Alex
Oops.
I have now enabled it in my router settings. Cheers for the heads up.
One last thing, I do not have a static IP so will this work? I just set up a new monitor and it's under a different IP.
Anyway, here is the link to the new one O have set up: http://www.thinkbroadband.com/ping/share/82c8329dc40035634a21b8599c3c1154.html
Re: TBB Ping Graphs
10-08-2012 2:59 PM
Can you monitor my connection if I have a dynamic IP?
We can only monitor your line if you have a static IP address as we are not able to track changes to your IP address at the moment. We will look at adding this functionality in a future version.
So, with a dynamic IP, it'll only work while you have the IP address assigned. If you're reconnected with a different IP, the monitor will stop receiving responses, or may receive responses from someone else who gets the address you used.
Re: TBB Ping Graphs
13-08-2012 5:03 PM
Quote from: P Your line looks perfectly fine, so I can only assume it is something that you have in place that essentially de-prioritises the pings?
Hi Phil,
As an experiment (and related to the 6in4 slowness I'm seeing) I'll be turning off traffic prioritisation on my connection and removing dummynet(4) entirely from the router's kernel. See if you can spot the time of the reboot in my graph.
Cheers,
A.
Re: TBB Ping Graphs
14-08-2012 10:10 AM
Re: TBB Ping Graphs
15-08-2012 6:33 AM
heres my link, i am on Extra Fibre with Pro-Addon
http://www.thinkbroadband.com/ping/share/855e2024fd9a49b64727c3e51fe93a67.html which gives
not sure if its posted right as it looks different once posted to what i have pasted in.
Russell
[Moderator's note by Dick (Strat) Link fixed
[color=green][Moderator's note by Jim (Oldjim) whole thing changed to show an image and link ]
Re: TBB Ping Graphs
15-08-2012 10:19 AM
Re: TBB Ping Graphs
15-08-2012 11:07 AM
Re: TBB Ping Graphs
19-08-2012 3:14 PM
Re: TBB Ping Graphs
19-08-2012 4:04 PM
If you read replies 2 and 3 on the first page of this topic there's no point in you giving the link to your graph while you are on a dynamic IP.
Re: TBB Ping Graphs
19-08-2012 5:38 PM
Happy to oblige
Plusnet Extra
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/92e029a95a4c24d5f4df5bc7e0c5e157-19-08-2012.html"><img alt="My Broadband Ping - Plusnet extra" src="http://www.thinkbroadband.com/ping/share-large/92e029a95a4c24d5f4df5bc7e0c5e157-19-08-2012.png" /></a>
Keith
