TBB Ping Graphs
Kelly
Fixes: 9
Re: TBB Ping Graphs
It isn't one long fibre to our POP.  Where is your exchange?
Kelly Dorset
Ex-Broadband Service Manager
chuckster
Re: TBB Ping Graphs
@Blim - Sorry for late reply.. router is a Netgear DGN2200.  Nothing special.
Jelv is right.. I'm not toooooo far away from that thar Londinium.
bomster
Re: TBB Ping Graphs
20CN Extra with Pro addon.
http://www.thinkbroadband.com/ping/share/82c8329dc40035634a21b8599c3c1154.html
Only just set it up, so it's empty right now.
bomster
Re: TBB Ping Graphs
I've hit my usage limit so I seem to be getting a reading of constant packet loss? On pingtest.net I just got 23ms?
You could always reset my usage? For scientific purposes, of course  ::).
houlton23
Re: TBB Ping Graphs
Looks to me like your router isn't responding to ICMP (ping) packets on it's WAN port. You need to look on your router's admin interface for the option to 'respond to ping on wan interface' or similar.
If you have one of the PN supplied Thomson routers this has to be done via telnet, however there is a guide to this here.
Alex Smiley
bomster
Re: TBB Ping Graphs
Quote from: houlton23
Alex Smiley
Oops.
I have now enabled it in my router settings. Cheers for the heads up.
One last thing, I do not have a static IP so will this work? I just set up a new monitor and it's under a different IP.
Anyway, here is the link to the new one O have set up: http://www.thinkbroadband.com/ping/share/82c8329dc40035634a21b8599c3c1154.html
kmilburn
Re: TBB Ping Graphs
[quote=http://www.thinkbroadband.com/ping]
Can you monitor my connection if I have a dynamic IP?
We can only monitor your line if you have a static IP address as we are not able to track changes to your IP address at the moment. We will look at adding this functionality in a future version.
So,  with a dynamic IP,  it'll only work while you have the IP address assigned.  If you're reconnected with a different IP, the monitor will stop receiving responses,  or may receive responses from someone else who gets the address you used.
avatastic
Re: TBB Ping Graphs
Quote from: P
Your line looks perfectly fine, so I can only assume it is something that you have in place that essentially de-prioritises the pings?
Hi Phil,
As an experiment (and related to the 6in4 slowness I'm seeing) I'll be turning off traffic prioritisation on my connection and removing dummynet(4) entirely from the router's kernel. See if you can spot the time of the reboot in my graph.  Wink
Cheers,
A.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Gus
Re: TBB Ping Graphs
Minor change to mine had interleaving removed last night after my connection has been rock solid since January, 55 to 35 ho hum the joys of a long phone line.  Not to see if it stays stable at peek times.
FTTP 500 regrade from Tues 28th November
Russellhouseman
Re: TBB Ping Graphs
Hi
heres my link, i am on Extra Fibre with Pro-Addon
http://www.thinkbroadband.com/ping/share/855e2024fd9a49b64727c3e51fe93a67.html which gives
not sure if its posted right as it looks different once posted to what i have pasted in.
Russell
[Moderator's note by Dick (Strat) Link fixed
[color=green][Moderator's note by Jim (Oldjim)  whole thing changed to show an image and link ]
Gus
Re: TBB Ping Graphs
@Russellhouseman use [code ] [/code ] instead of [quote ] [/quote ] that way to keeps any formating
Chris
Legend
Fixes: 169
Re: TBB Ping Graphs
I'll put any that I've missed on to the page later today.
bomster
Re: TBB Ping Graphs
Please Delete.
jelv
Fixes: 10
Re: TBB Ping Graphs
@bomster
If you read replies 2 and 3 on the first page of this topic there's no point in you giving the link to your graph while you are on a dynamic IP.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
kaybee327
Re: TBB Ping Graphs
Hi Chris
Happy to oblige
Plusnet Extra
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/92e029a95a4c24d5f4df5bc7e0c5e157-19-08-2012.html"><img alt="My Broadband Ping - Plusnet extra" src="http://www.thinkbroadband.com/ping/share-large/92e029a95a4c24d5f4df5bc7e0c5e157-19-08-2012.png" /></a>
Keith
