TBB Ping Graphs
Legend
Fixes: 168
Re: TBB Ping Graphs
All added
Fixes: 459
Re: TBB Ping Graphs
Mind that step at 3:30am Chris Wink
Customer and Forum Moderator. Windows 10 Firefox 79.0 (64-bit)
Legend
Fixes: 168
Re: TBB Ping Graphs
Your minimum latency seems to be higher than most others Gus, I'm assuming that you're on an interleaved line?
For all the others that have given graphs, many thanks. If you'd like to give us a brief 1 or 2 line explanation of any oddness, spikes or anything else on the graph that'd be great and I can then put that on the page too.
Re: TBB Ping Graphs
Yep it is interleaved on long line, my spikes will be VLC streaming BBC radio or browser for my local station, plus a MMO gamer so I usually have VLC/2 game clients running at the same time
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 7
Re: TBB Ping Graphs
Extra 21CN
Sorry to be late posting, suffering from a cold currently.
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/d301982cde4ecd8ab3dd25308e0a2aac.html"><img alt="My Broadband Ping - PlusNet" src="http://www.thinkbroadband.com/ping/share-large/d301982cde4ecd8ab3dd25308e0a2aac.png" /></a>
That's RPM to you!!
Re: TBB Ping Graphs
avatastic,
I've been looking at your throughout the afternoon. Now I am running under the assumption that you know why it looks like that, because to anybody else it must be screaming "what the ..".
Your line looks perfectly fine, so I can only assume it is something that you have in place that essentially de-prioritises the pings?
Re: TBB Ping Graphs
P,
Yeah I expect that icmp is being put in pipes 3 and 4. I keep the highest priority pipes (1 and 2, unsurprisingly) for things like incoming DNS lookups.
I'll move icmp in to pipes 1 and 2 and see if my graph settles down.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Re: TBB Ping Graphs
Today at 3pm ish the change in packet loss or lack of thankfully, I had my SNR reset to 6 after BT changed it to 3 yesterday.  Had random sites failing to load and buffering on all on-demand sites I use [4OD/Iplayer/channel5]
Re: TBB Ping Graphs
Hohoho, looks like the Steam "tweak" to download updates on a timer seems to be working on mine.  At last, I can schedule downloads of all the games I never managed to get down yet Smiley
Fixes: 62
Re: TBB Ping Graphs
What tweak - I  always do it using task manager
Re: TBB Ping Graphs
Here's mine:
Extra
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/a43201d028e92661224997c8511a42d7.html"><img alt="My Broadband Ping - PlusNet Main" src="http://www.thinkbroadband.com/ping/share-large/a43201d028e92661224997c8511a42d7.png" /></a>
Re: TBB Ping Graphs
chuckster,
what router do us use? I see your ping is under 10ms.
Fixes: 10
Re: TBB Ping Graphs
It won't be anything to do with his router - it will be that he is close to London.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 9
Re: TBB Ping Graphs
He's probably connected to our POP with a CAT6 cable Cheesy
Kelly Dorset
Broadband Service Manager
Re: TBB Ping Graphs
funny that coz my exchange is less than 100 meters away and thats connected to London by fiber.
and from your calculations I should get a ping well over 3 seconds to say the US.
just admit you or bt ether use interleaving to manage the speed of your customers connection or connection shaping.
