Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
23-03-2013 10:09 PM
Your problem is very similar to Finguz's slow downs (which has finally been identified as congestion in BT's network).
Do you know any other people on the same exchange as you with speed issues?
23-03-2013 10:15 PM
Today I have found a configuration work around that has got my line back to full speed (8.128Mbps), my line profile is still recovering (currently 7.0Mbps), and my line is now virtually error free.
However my latency is still 15ms higher than it was a few weeks ago, and as I was reporting two weeks ago my speedtest results have dropped 500Kbps to 800Kbps all the time - when for the last few YEARS it was unusual to see a speedtest result drop more than 200Kbps at peak times.
I'll be back on the case with Chris Pettitt on Monday to start getting my initial issue corrected.
23-03-2013 10:17 PM
23-03-2013 10:24 PM
@ jamesanstee Sounds like you had an unhelpful engineer. He certainly shouldn't start blaming the CP when he has no proof that the fault lies with them.
23-03-2013 10:25 PM
ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 11.8 24.0
Attn(dB): 9.0 5.0
Pwr(dBm): 13.8 12.2
Max(Kbps): 8448 1144
Rate (Kbps): 8128 448
24-03-2013 2:01 AM
24-03-2013 2:32 AM
Your download speed looks to me to be exactly the speed I would expect (and get myself) for a 6.5mbps Profile. Have you checked your Current Line speed ?
24-03-2013 6:24 AM
Whtiebox results below and attachment for yesterday plus speedtes.nett result for this morning
I'm still on gateway plc-ag08 and have been for last 5 days.
Downstream Throughput
Date 23.3.2013
Average (Mbps)
20:00 50.00
18:00 22.41
16:00 51.37
10:00 55.01
04:00 51.33
24-03-2013 9:19 AM
Quote from: Anotherone @purleigh
Quote from: purleigh ...my line back to full speed (8.128Mbps), my line profile is still recovering (currently 7.0Mbps), and my line is now virtually error free.
So yes my "Current Line speed" was 7.0Mbps at the time of the above test.
Quote from: purleigh However my latency is still 15ms higher than it was a few weeks ago, and as I was reporting two weeks ago my speedtest results have dropped 500Kbps to 800Kbps all the time - when for the last few YEARS it was unusual to see a speedtest result drop more than 200Kbps at peak times.
This was already happening BEFORE my line went wrong last week, the increased latency has been there for weeks and the speed offset seen in my speedtest results tracked with the changes in line profile at 7.15, 7.0, and 6.5Mbps.
24-03-2013 11:47 AM
24-03-2013 9:25 PM
Latency for the last week has been 31 to 33ms.
No line errors, current line speed = 7Mbps
Browsing felt unresponsive so did a pingtest and found out why ! -
Gateway hopped to 'ptw-ag04', result looked a little better but still not good !
Hopped again to 'pcl-ag03' and got better again -
26-03-2013 9:57 AM
Ive not had any problems for 2 weeks or more now
26-03-2013 11:28 AM
26-03-2013 11:35 AM
I think the changed minimum at around 7pm and packet loss is when it lost sync due to me ringing in to tell my wife what time I expected to be home.
26-03-2013 2:36 PM
And now... I believe that the "impovements" that Plusnet have made recently have upset the karma of my connection! Fortunately for me, I'm not a "gamer" else I would be a bit peeved.
