Peak time latency spikes
englishrick
Re: Peak time latency spikes
BTW speed tester gives me same results!!So that rules that one out!!!
Bright
@englishrick
Clearly something is wrong, although it does look as if your problems might be caused by something different from what is causing the peak-time slow down others are experiencing. Or perhaps something else as well as the more general slow-down issue.
Could I just check whether your speed tests are run over wifi or ethernet? I have a recollection from when this started that you are using wifi, but that may be wrong...
20CN  on  'ptw-ag01'
First result for a new week !
englishrick
@Bright.... I am using Ethernet mate
AndyH
Do you live near Willaston? There was another user experiencing slow downs on the Broadband and Routers forum....would be interesting to see if he's still getting problems
englishrick
@AndyH.. Willaston is about 10 miles away.. There was another user from the other end if my village having problems Matt something his name was
gary42
I'm seeing some loss of speed at peak, maybe a few Mbits, but the main symptom I see is large variation in latency spikes when the connection is being used at different times of the day.
The image below shows some usenet downloads running (Circled). The one running at 00.30 was actually running at a higher speed.
The activity around 07.30 this morning was youtube streaming running at line speed.
Generally it doesn't affect us too much however I thought it was an interesting comparison. Not something I have seen with my previous ISP's.
I have two lines and both exhibit the same behavior. Currently on pcl-ag01 and 06. ADSL2+, unlimited product.
rja
Some variable results for me over the weekend. These are all on ptn-ag01
Friday:
22:00 48.87
20:00 51.14
18:00 51.67
14:00 51.86
08:00 51.39
02:00 50.29
Saturday:
22:00 51.38
20:00 51.15
18:00 51.14
14:00 52.17
08:00 51.85
02:00 51.60
So, pretty stable there. But then Sunday:
22:00 37.13
20:00 42.61
18:00 51.49
14:00 51.65
08:00 51.69
02:00 51.70
So, not great from 20:00 onwards. Sunday's ping graph is rathr different to Friday and Saturday's also. In all cases there was pretty much nothing happening on the line during these periods.
bobpullen
Fixes: 327
Quote from: Bjn
Ok my line stats from SamKnows white box on three gateways over last week
I'd be interested in seeing some more screen grabs from the SamKnows testing if you're able to provide them? In particular stuff from last Friday evening (15th) onwards. Curious to see how they compare to the ones you posted here.
Bjn
@ Bob Pullen
Ok Bob the screen shots you requested from my whitebox which are much better than the previous ones. Last time I had any big dip was 13th March so posting last week of daily screen shots for you to see improvement.
on gateway plc-ag01 until 11.20 on 16th then hoped over to gateway ptn-ag01 as I was having very bad problems Saturday morning on both down/up speeds.
KevinG
I now have a static IP and a BQM! First day shows higher latency in the evening but it hasn't affected me noticeably.
jelv
Fixes: 10
SamKnows latency for Sunday 17/03
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
englishrick
Well its off peak and no slowdown yet!!!! So have any of the PN staff got any news on whether there is a problem at my exchange?? as you did say monday..
Chris
Legend
Fixes: 169
We're still waiting for an update, we'll keep chasing and let you know as soon as we find out. Sorry :(.
I'm thinking it might be worthwhile asking the moderators to split your posts out into a separate thread as it's likely the issue is exchange based from the other customers we've found having the same issue at your exchange.
AndyH
Well BT have updated their spreadsheet today for "sites with capacity issues" and it's not changed from last week (still only listing Tiverton/Ilford Central). Unless that spreadsheet is exchanges that are unable to take new connections, I think BT need a kicking!
(Apologies to mods if the thread is going to be split for exchange issues)
