Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
17-03-2013 9:38 PM
On speedtest.net, you can 'save' your chosen server.
In the top right hit 'SETTINGS', then in the "Global Settings" choose your "Preferred Server".
Next time you run a test, you will see a new button that allows you to test your preferred server - without having to select it from the map.
17-03-2013 9:41 PM
Ex-Plusnet Jobsbody
17-03-2013 9:49 PM
Does it explain why my speedtests are recently often 500Kbps less than my profile, even off peak ?
17-03-2013 9:50 PM
17-03-2013 9:52 PM
17-03-2013 9:57 PM
Quote from: Anotherone I always use Milton Keynes because that has always given me the "best" results
I noticed quite a few people end up using Uno's MK servers for pingtest.net but I didn't get why that was the lowest ping. In theory, the London servers should the lower pings as that is where PN's gateways are based. They certainly give me the lowest pings and I live in Milton Keynes!! Also, Uno/Xilo use BE's network, I believe, so there is an extra hop or so in there.
17-03-2013 9:58 PM
You and your big mouth!
Quote from: Anotherone Ha, I reckon everyone is using Milton Keynes now, I've just had the most erratic results that I've had in months including !+Mbps above my profile
17-03-2013 9:58 PM
17-03-2013 10:14 PM
Only problem I had over weekend was the Saturday morning for an hour when both up and down speeds dropped very low for an hour, then down returned to normal but up speed stayed low for a while. It may have been the BT speed test as speedtest.net/thinkbroadband both gave normal speeds.
On gateway PTN-AG01
17-03-2013 10:27 PM
17.03.2013 22:23 GMT 72.21 Mb/s 17.87 Mb/s 6 ms Structured Communications
17.03.2013 22:22 GMT 72.27 Mb/s 17.86 Mb/s 6 ms Uno
17.03.2013 22:20 GMT 71.42 Mb/s 17.81 Mb/s 5 ms Namesco
17.03.2013 22:19 GMT 72.27 Mb/s 17.11 Mb/s 14 ms Vodafone
17.03.2013 22:16 GMT 55.54 Mb/s 10.99 Mb/s 6 ms FidoNet
17.03.2013 22:15 GMT 70.83 Mb/s 6.10 Mb/s 5 ms Namesco
17.03.2013 22:14 GMT 72.19 Mb/s 17.84 Mb/s 7 ms Xilo
17-03-2013 10:44 PM
17.03.2013 22:40 GMT 63.64 Mb/s 17.88 Mb/s 5 ms London - Namesco
17.03.2013 22:39 GMT 62.37 Mb/s 17.81 Mb/s 6 ms Maidenhead - Xilo
17.03.2013 22:39 GMT 47.36 Mb/s 17.89 Mb/s 7 ms Milton Keynes - Uno
18-03-2013 5:11 AM
18-03-2013 7:03 AM
No one is not saying it could be congestion at your exchange at peak times but you need to rule out all other possibilities so PN can give BT some real data to show it could be.
If as you say and seem convinced that it's congestion (and I'm not saying it's not) then it's over to BT and I wish you all the luck in the world having to wait for them to upgrade the exchange and install more capacity to your linked exchange.
At least you think you have found out what your problem is then you don't seem to be suffering from the same problem a near complete collapse of speed well under 10Mbps that others have been during peak time on fibre, Your speed has dropped but it's still faster than some can get without the peak time problem,your last slow post was 37Mbps. mine for example was 3.6Mbps from 51Mbps and that was Saturday morning. I'd be happy with a slowdown to a slow 37Mbps at peak times during this period of problems.
Maybe now you can try and help others and PN who are still trying to workout what the problem is as they have with your problem?
Last nights results from my whitebox which is showing a great improvement over the last 3 weeks
Gateway ptn-ag01
Downstream Throughput
Date 17.03.2013
Average (Mbps)
22:00 51.62
20:00 46.89
18:00 51.26
16:00 53.07
10:00 51.33
04:00 51.23
18-03-2013 7:26 AM
18-03-2013 7:45 AM
