Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
16-03-2013 11:27 PM
16-03-2013 11:29 PM
17-03-2013 6:39 AM
Bob
17-03-2013 6:47 AM
Quote from: englishrick Asus N56
Could be your router I had an Asus N56U and it was very intermittent re connections/speed, router looked as if it never dropped connection but PN confirmed it was, after a few calls to Asus Tech support they confirmed the router was faulty so I returned it to Amazon. That was before Christmas and I started using th PN router again which cured both problems until the 23rd Feb when the speed problems we have been having started. Just a thought I maybe wrong re the router but worth ruling out.
I was out last night so can't report any speed issues, but whitebox showing speeds OK with a slight dip in speed about 10pm (only a couple of Mbps down so no real issues)
Re BT wholesale testers I was getting problems with that yesterday even though Speedtest/thinkbroadband where reporting speed OK as was Pingtest so putting that down to BT having a bad session as it back OK this morning.
Gateway on ptn-ag01 and just watched iPlayer on TV with no problems
17-03-2013 7:40 AM
17-03-2013 8:44 AM
17-03-2013 12:38 PM
I was thinking about the router, but it's a bit strange that at peak times englishrick's speed slows down dramatically and then return to normal (or near normal) afterwards. Router faults tend to be consistent and I don't think there are any reported serious bugs like speed loss with the N56U.
The TBB graph looks pretty good which adds to the mystery but I guess tonight's peak time will be useful info.
17-03-2013 2:43 PM
17-03-2013 4:18 PM
Re the router problem I had with Asus N56u was intermittent, could be englishrick problem at peak time then back to normal is more prominent as this is when he's doing speed tests more often then any of us would normally do. If you are just doing normal surfing the net you would never have known. The problem showed up with large data downloads and video streaming and as most of the time I was surfing web pages that's what had the Asus guys perplexed.
Just a though and I maybe totally wrong but something to rule out?
Speed wise today I'm OK on ptn-ag01
17-03-2013 4:20 PM
17-03-2013 4:33 PM
17-03-2013 5:33 PM
17-03-2013 5:52 PM
17-03-2013 6:00 PM
17-03-2013 6:06 PM
http://usertools.plus.net/exchanges/mso.php?id=11620
