Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
01-03-2013 8:56 PM
01-03-2013 9:06 PM
I'm on gateway pcl-ag08 and thought I'd add that I've noticed the latency problem on that gateway, and similar to MsDizzie, improved later on though at around 8:50 or so.
01-03-2013 9:13 PM
01-03-2013 9:13 PM
01-03-2013 9:16 PM
I was on ptn-ag02 getting pings to www.plus.net of between 28ms and 107ms. Reconnected to ptw-ag03 and now steady pings of 28-30ms, and websites are loading again.
01-03-2013 9:28 PM
01-03-2013 9:33 PM
gateway pcl-ag07. Normal download - 52mb upload - 9 mb
01-03-2013 9:37 PM
01-03-2013 9:38 PM
01-03-2013 9:49 PM
01-03-2013 9:54 PM
My speeds have dropped off quite a lot now, just in time for my Halo sesh :'(. Ping is four times what it was earlier and download speed is a sixth of what it was. Upload speeds have remained pretty consistent.
This is what it was 2 hrs ago:
Ping: 9ms
Download Speed: 70.46Mbps
Upload Speed: 16.80Mbps
Been on pcl-ag02 all throughout.
01-03-2013 9:54 PM
You log into your modem/router or router if Fibre and go to the Internet Box and use the Disconnect button. Wait about 30seconds and then click Connect. Don't forget to check which Gateway you were on and are then on so you can report the results.
01-03-2013 9:56 PM
01-03-2013 9:57 PM
01-03-2013 10:01 PM
Speed normal every time I've checked so far tonight. Pings better than last night, a lot less variability.
Reply from 212.159.6.10: bytes=32 time=39ms TTL=250
Reply from 212.159.6.10: bytes=32 time=37ms TTL=250
Reply from 212.159.6.10: bytes=32 time=42ms TTL=250
Reply from 212.159.6.10: bytes=32 time=41ms TTL=250
Reply from 212.159.6.10: bytes=32 time=47ms TTL=250
Reply from 212.159.6.10: bytes=32 time=38ms TTL=250
