Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
28-02-2013 9:32 PM
28-02-2013 9:33 PM
It could be that the two problems are connected, however, with the first problem, we see one of the devices stuck at 100% CPU. We don't see that associated with the more generic slowdowns.
Ex-Plusnet Jobsbody
28-02-2013 9:34 PM
See the second half of my post. In particular the note about the gateway that worked perfectly for AndyH but at exactly the same time was giving me severe performance problems.
28-02-2013 9:38 PM
Ex-Plusnet Jobsbody
28-02-2013 9:39 PM
Jitter is climbing and the line rating is decreasing.
TBB graph:
I'll have another check on this later - 10ish last night was bad, so will try again then.
28-02-2013 9:45 PM
28-02-2013 9:53 PM
Pages are slowing and basic websites such as Facebook that usually loads instantly on my 78Mb fibre connection is taking 10-20 seconds to load completely so I am not sure if DNS is maybe involved in this as well.
28-02-2013 9:53 PM
And this is just now:
And this was last night:
All of these were on: pcl-ag02
Not great.
Edit: although my monitor looks suprisingly healthy:
28-02-2013 9:54 PM
Much better this evening, still on pcl-ag08
PING bbc.co.uk (212.58.241.131) 56(84) bytes of data.
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=1 ttl=245 time=14.5 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=2 ttl=245 time=14.2 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=3 ttl=245 time=14.7 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=4 ttl=245 time=26.7 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=5 ttl=245 time=14.6 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=6 ttl=245 time=14.5 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=7 ttl=245 time=15.1 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=8 ttl=245 time=15.8 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=9 ttl=245 time=14.9 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=10 ttl=245 time=26.8 ms
64 bytes from virtual-vip.thdo.bbc.co.uk (212.58.241.131): icmp_req=11 ttl=245 time=14.5 ms
^C
--- bbc.co.uk ping statistics ---
11 packets transmitted, 11 received, 0% packet loss, time 10013ms
rtt min/avg/max/mdev = 14.238/16.993/26.895/4.663 ms
Bob
28-02-2013 10:00 PM
Ex-Plusnet Jobsbody
28-02-2013 10:06 PM
BTw tester 0.4-0.5Mbps slower than normal (usually 6.2Mbps)
BBC Diagnostic attached - figures are normally all over 6000kbps,
but pings not as bad as earlier -
Reply from 212.159.6.10: bytes=32 time=41ms TTL=250
Reply from 212.159.6.10: bytes=32 time=39ms TTL=250
Reply from 212.159.6.10: bytes=32 time=42ms TTL=250
Reply from 212.159.6.10: bytes=32 time=37ms TTL=250
Reply from 212.159.6.10: bytes=32 time=38ms TTL=250
Reply from 212.159.6.10: bytes=32 time=46ms TTL=250
Reply from 212.159.6.10: bytes=32 time=44ms TTL=250
Reply from 212.159.6.10: bytes=32 time=40ms TTL=250
28-02-2013 10:08 PM
28-02-2013 10:25 PM
Oddly the pingtest results are better:
But the TBB graph has just started producing big spikes again - only just visible but this is similar to last night
I'll do another set before I sign off for the night - I'm feeling slightly less grumpy tonight too, perhaps it shows
28-02-2013 10:31 PM
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.94]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 16 ms 22 ms 15 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194
3 12 ms 11 ms 11 ms link11-central10.ptw-gw01.plus.net [84.93.248.11
6]
4 11 ms 13 ms 11 ms xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
5 11 ms 11 ms 11 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
6 * * * Request timed out.
7 13 ms 13 ms 12 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
8 16 ms 13 ms 13 ms 132.185.255.165
9 12 ms 12 ms 12 ms bbc-vip015.cwwtf.bbc.co.uk [212.58.246.94]
Trace complete.
C:\Users\Private>
28-02-2013 10:32 PM
Ex-Plusnet Jobsbody
