Peak time latency spikes
ricmelia
Re: Peak time latency spikes
I'm also on ptw-ag04, have never tried disconnecting to hop to another gateway.
Web/youtube streaming/ftp are all affected at the moment, usenet is fine. Last night everything recovered at 11:15-11-20ish
Current results:
(All my speedtests are available in my signature)
Tracing route to www.bbc.net.uk [212.58.246.95]
over a maximum of 30 hops:
 0  SERVER.lan [192.168.1.70]
 1  dsldevice.lan [192.168.1.254]
 2  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
 3  link13-central10.ptw-gw01.plus.net [84.93.248.120]
 4  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
 5  ae2.ptw-cr02.plus.net [195.166.129.5]
 6  ae2.ptw-cr01.plus.net [195.166.129.4]
 7  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
 8     *        *        *
Computing statistics for 175 seconds...
           Source to Here   This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                               0/ 100 =  0%   |
 1    0ms     0/ 100 =  0%     0/ 100 =  0%  dsldevice.lan [192.168.1.254]
                               0/ 100 =  0%   |
 2   15ms     0/ 100 =  0%     0/ 100 =  0%  lo0-central10.ptw-ag04.plus.net [195.166.128.194]
                               0/ 100 =  0%   |
 3   11ms     0/ 100 =  0%     0/ 100 =  0%  link13-central10.ptw-gw01.plus.net [84.93.248.120]
                               0/ 100 =  0%   |
 4   10ms     0/ 100 =  0%     0/ 100 =  0%  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
                               0/ 100 =  0%   |
 5   12ms     0/ 100 =  0%     0/ 100 =  0%  ae2.ptw-cr02.plus.net [195.166.129.5]
                               0/ 100 =  0%   |
 6    9ms     0/ 100 =  0%     0/ 100 =  0%  ae2.ptw-cr01.plus.net [195.166.129.4]
                               0/ 100 =  0%   |
 7   10ms     0/ 100 =  0%     0/ 100 =  0%  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
Trace complete.
jamesanstee
Latest traceroute : 22:20
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.69]
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2    37 ms    37 ms    35 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197
  3    *      62 ms    72 ms  link4-central10.ptw-gw02.plus.net [84.93.248.70]
  4    63 ms    77 ms    69 ms  xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
  5    64 ms    63 ms    65 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  6    55 ms    58 ms    56 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    54 ms    52 ms    49 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10    70 ms    73 ms    76 ms  132.185.255.148
11    70 ms    77 ms    80 ms  bbc-vip114.telhc.bbc.co.uk [212.58.244.69]
Trace complete.
C:\Users\Private>
Bright
21CN (FTTC) and gateway: pcl-ag07. No problems here with throughput or latency.
Quote from: Anotherone
I don't think Kelly meant the 20CN platform was "congested"?Huh
Sorry, I meant certain parts of the platform - affecting some users only. Same with the BTW 21CN WBC platform. I meant it as a question... whether that is the current theory?
But I see that there are quite high latency spikes on the 21CN graphs for bronze/best effort now - not as high as last night, I think. Does that imply a problem within Plusnet's network?
Can anyone tell us what those graphs actually represent? Are they based on test traffic through each gateway (rather than actual measurements of customer traffic)? And where are the test end points, ie they are measuring latency between where and where?  Just interested to know what they are really telling us.
20CN,  'ptn-ag04'
No problems here at any time this evening, both ping times and speedtest results normal.  Cool
jamesanstee
Just changed to gateway pcl-ag05  speed almost back to normal.
jelv
Fixes: 10
SamKnows latency from yesterday (Mon 25th).
Today's is looking pretty similar.
Gateway pcl-ag05 both days.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Anotherone
Champion
Fixes: 21
Quote from: purleigh
20CN,  'ptn-ag04'
You've got 23ms ping in your sig compared to 41in the test result unless your are trying to say 41 is normal with interleaving on and 23 was what you got with it off.
Same Gateway here, but slightly elevated pings earlier, just a few spikes (probably me) since about 2200.
Jaggies
Just come back home and tested again -
Back to normal at 00:20
RPMozley
Seasoned Pro
Fixes: 16
TBB ping monitor with signs of increase in average latency during peak time. (26-02-2013) pcl-ag03
But comparing that to the IPv6 ping graph there's no sign during peak time.
Ignore the 4 - 6 pm as iPlayer downloads were running.
As both connections go through the same route up to the outer end of the PlusNet network, it appears to be something outside of PN's control where the issue lies.  Sad
Edit: Added dates and gateway, just in case.  Wink
That's RPM to you!!
jelv
Fixes: 10
Here's yesterday's (26th) latency.
BTW: I was expected to see more recent tests on the speedtest.net Plusnet Community speedwave.
chrispurvey
If you're experiencing the issues discussed in this thread, would it be possible for you to run through our faults wizard at http://faults.plus.net so we can investigate this further with our suppliers.
If you could let me know when you've done this I'll get this followed up and update you ASAP.
Thanks,
Chris
Kelly
Fixes: 9
Quote from: RPMozley
Who are you using for the IPv6 tunnel?
Kelly Dorset
Ex-Plusnet Jobsbody
ricmelia
Hi Chris,
I've got a fault open already (I think - someone in support started it and I've not had to run any tests) - all I've been asked to do is connect directly to the modem to rule out the router being the problem (which I've not done yet)
Should I run through the faults wizard anyway?
Kelly - did you get the message with the link to the wireshark captures last ngiht?
Ric
Kelly
Fixes: 9
Yep, got the wiresharks.  I need Dave to have a look at them next week (He's off on hols this week) but they look fine from my untrained eye.
Kelly Dorset
Ex-Plusnet Jobsbody
