Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
20-03-2013 10:21 PM
Quote from: AndyH @ Finguz
To get the test 3 to work, you need to run the normal BT test and go through the further diagnostics page, it will say there are problems with you line and press continue to run further tests. It then gives you the TAP3 login details, you login, press continue then the test works.
Yup as I have done countless times previously. I run the speedtest ( logged in and connected with my plusnet login ), then the second part ( logged in and connected with my plusnet login ) , then enter the speedtest login, as requested, then click continue and get the following...
Thanks for attempting to help though, it's appreciated
20-03-2013 10:25 PM
20-03-2013 10:26 PM
Same result.
dick:quote
20-03-2013 10:30 PM
Address 1: 193.113.4.154
Address 2: 193.113.4.153
Address 3: 193.113.8.194
Address 4: 193.113.8.193
20-03-2013 10:31 PM
20-03-2013 10:41 PM
Tap3 will run just fine with the plusnet login but not at all with the speedtest login.
20-03-2013 10:43 PM
Best add these to the TAP3 test thread.
20-03-2013 11:06 PM
Fed up with banging my head against a wall, off to bed.
Thanks for trying to help though
ptn-ag01 via my friends HH3 ( their connection was perfectly fine too, before I borrowed the router anyway )
20-03-2013 11:10 PM
Quote from: Kelly I think Finguz had a fault last time we looked at it? Not sure if that was resolved? We'll check tomorrow again!
There was no fault, it is just the speed issue. The engineer did every conceivable test and my line is just fine.
The plusnet tech guy thought there was an issue because of multiple router disconnects, but that was me hopping to try and find a useable connection. I then disconnected and reconnected my modem a couple of times in a 12 - 24 hour period and hosed my profile, which has now been reset.
21-03-2013 5:12 AM
21-03-2013 6:52 AM
Speed, video streaming P2P and browsing all OK on gateway plc-ag08
Downstream Throughput Date 20.3.21013
Average (Mbps)
22:00 51.35
20:00 52.69
18:00 51.37
16:00 51.40
10:00 53.13
04:00 51.38
21-03-2013 8:05 AM
Quote from: Finguz I've tried default, google, open dns and several others.
@Finguz
When you connect to the BT test realm your router will be assigned the BT DNS servers that are accessible on the test network. None of the "normal" DNS services are accessible on this network. So your router should not be assigned a fixed DNS service (it will get this by DHCP during the PPP login). And likewise the PC you are using to run the test should also not have a fixed DNS service. I assume your router acts as the DHCP server for your network, so it should assign a DNS server address to the PC - it will probably assign its own address and it will then relay the DNS traffic to the BT servers that it has been assigned. You'll probably need to make sure you have everything set up this way before you start the first test with your Plusnet login (which will assign the Plusnet DNS server addresses to your router for the first 2 stages).
21-03-2013 8:42 AM
Now this is odd. Speed still low this morning
Normal speed would be..
21-03-2013 9:38 AM
**Edit**
Do you have a TBB graph set up too?
Btw...I found slow downs (exchange congestion) 9:30-10:30 14:00-15:00 16:00-17:30 20:00-21:30 - the worst for me was the 16:00-17:30 period which I assume was the school kids streaming/p2p etc.
21-03-2013 9:42 AM
