| Quote from: Anotherone |
@purleigh There was 2 hidden users when I last looked.
I don't care, the fact is that this thread has been running for TWO MONTHS, some of us are now worse off now than ever, and for a so called 'PRIORITY PROBLEM' there are no staff sitting glued to this thread WHEN THE PROBLEMS ARE HAPPENING to provide real time support, suggestions and feedback to those of us that are trying to help get to the bottom of whatever is going wrong.
| Quote from: dave |
| Quote from: purleigh | 20CN on 'pcl-ag01' Lost it now, test after test has collapsed in speed !
Exchange looks OK (we have a 20CN list, waiting on the 21CN one), line looks fine, network looks fine and PCL-AG01 looks fine. Try a disconnect/reconnect.
What is the point of keep being asked to disconnect/reconnect, because you know the outcome before we do it !
Night after night someone reports that they have stumbled upon a bad link, hops to another gateway, and the problem disappears !. So bloody what !. How is this getting closer to fixing the problem ? Plusnet need to be running forensic trace on these faulty connections and discovering the root cause of whatever is going wrong - not hopping to another gateway and saying "yes that last one really was bad after all".
[quote=Kelly]Some of the line cards we are using can handle x amount of traffic. Unless they are configured in a certain way. If they are configured in that way, they drop by y amount of traffic, leading to a capacity of x-y.
We don't have specific graphing on those cards so can't be sure we've been exceeding x-y, but based on our traffic levels at the minute it is possible. Those cards now have graphing, and we've changed the config so the cards can handle x
Whatever the last change Plusnet did regarding changing the overhead calculation on their line cards, since then my connection seems to have had a permanent 500Kbps loss (below my "Current Line Speed"). Is that change permanent or is it going to be fixed ?.
[quote=dave]Exchange looks OK (we have a 20CN list, waiting on the 21CN one), line looks fine, network looks fine and PCL-AG01 looks fine
Oh yes, it must all be in my imagination then >:(
