Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
10-03-2013 7:18 PM
Quote from: Anotherone rookey, Which Gateway are you on?
Dont know what I was on before but I just Hopped to see if it solved the problem now on
You are currently connected to gateway pcl-ag01.
This is located in City Lifeline House.
10-03-2013 7:20 PM
Quote from: AndyH @ rookey - Can you post your usage stats from the member centre?
This what you wanted?
Current billing period: Feb 12 2013 - Mar 11 2013
12 Tue 13 Wed 14 Thu 15 Fri 16 Sat 17 Sun 18 Mon Total
Allowance Used 512.29MB 1.1GB 416.89MB 3.1GB 408.15MB 315.77MB 534.85MB 6.4GB
Overnight Usage 5.93MB 53.94MB 235.82MB 114.32MB 15.85MB 39.14MB 69.51MB 534.5MB
Total 518.22MB 1.16GB 652.71MB 3.22GB 424MB 354.9MB 604.35MB 6.93GB
19 Tue 20 Wed 21 Thu 22 Fri 23 Sat 24 Sun 25 Mon Total
Allowance Used 425.43MB 579.01MB 731.84MB 371.75MB 935.61MB 778.55MB 523.44MB 4.35GB
Overnight Usage 83.97MB 293.22MB 39.19MB 55.45MB 90.33MB 5.83MB 17.74MB 585.72MB
Total 509.4MB 872.22MB 771.03MB 427.19MB 1.03GB 784.37MB 541.17MB 4.93GB
26 Tue 27 Wed 28 Thu 01 Fri 02 Sat 03 Sun 04 Mon Total
Allowance Used 757.99MB 387.95MB 654.66MB 841.83MB 252.21MB 633.84MB 1.38GB 4.91GB
Overnight Usage 62.92MB 20.86MB 41.24MB 133.18MB 70.12MB 169.11MB 54.46MB 551.89MB
Total 820.91MB 408.81MB 695.89MB 975.01MB 322.33MB 802.94MB 1.43GB 5.46GB
05 Tue 06 Wed 07 Thu 08 Fri 09 Sat 10 Sun 11 Mon Total
Allowance Used 1.28GB 948.6MB 725.18MB 862.74MB 975.22MB 84.98MB - 4.87GB
Overnight Usage 182.4MB 83.66MB 38.62MB 7.46MB 63.3MB 216.78MB - 592.23MB
Total 1.46GB 1.03GB 763.8MB 870.2MB 1.04GB 301.76MB - 5.47GB
10-03-2013 7:29 PM
10-03-2013 8:02 PM
10-03-2013 8:07 PM
Ping reaching 129 at moment.
10-03-2013 8:09 PM
Having just compared my connection with my friends who I been at all day who's on bt broadband his much more stable and quicker hmmmm
10-03-2013 9:27 PM
General web browsing is slow and I suspect any attempt to stream would result in the spinning circle of doom.
pcl-ag07
Upload speeks spike at the very end of the test, otherwise are about 0.17, download hovers around 3Mb/s and then spikes to the result seen at the end.
Going to ditch this gateway so I can start a new monitor, as other one went red when the router dropped connection.
Any input from PN staff?
10-03-2013 9:37 PM
10-03-2013 9:44 PM
10-03-2013 9:59 PM
As I have said before, this should not be necessary! I am sure there are people who have left Plusnet as they do not know this is the problem and that hoping gateways will probably sort it - but why should we have to keep doing this - there is clearly a network issue. There are nearly 50 pages of info and data here, how much more do we need to provide. This is really getting beyond a joke, and one of those really bad Christmas cracker ones at that... Speaking of Christmas, will my internet work without problems by then?!
So, now on ptw-ag03 and getting the following:
Just as bad, speed is low until the end of the test. Actual average speed was c. 2Mb/s - now getting really hacked off with this - off to gateway jump again. I'm thinking of charging PN a fiver each time I have to log in to my router for 'admin costs'!! Even listening to classical music is not calming me down
10-03-2013 9:59 PM
My gateway is 'ptw-ag04', on 20CN ADSL.
My TBB graph is quite normal and flat.
My browsing is working fine, not laggy at all.
Pingtest and speedtest report latency of 64ms, but using ping in a console gives 30ms. - usually they are similar !
"Speedtest", iPlayer test, and "mybroadbandspeed", ALL say my speed has collapsed from 7150Kbps to 2700Kbps.
My router stats are normal and synced at full speed.
My Plusnet profile is 7150Kbps.
I have only previously seen latency issues but tonight my speed has dropped to a third !
What is unusual is that when running the speedtests, normally there is a few peaks and troughs as the test progresses, but currently they are remarkably flat.
10-03-2013 10:12 PM
Maybe the PN network is buckling as a result of the ad campaign. Contrary to the official position about no capacity issues, surely it is common sense that when people get home from work, have dinner and fire up the internet it is about 7pm - the time the internet slows down - and then starts to speed up around 11pm, bedtime?
Not sure what else we can do/expect as this has been going on for a while and shows no signs of being fixed, very disappointed in the overall service performance from PN in terms of the internet speed an reliability. Staff are very helpful and have been keen to try and resolve these problems, but there is no excuse whatsoever for allowing this to drag on for so long. Are those of us who have posted going to be given some sort of compensation for this, free month(s), a refund etc?
10-03-2013 10:15 PM
10-03-2013 10:48 PM
11-03-2013 9:06 AM
Quote from: purleigh Pingtest and speedtest report latency of 64ms, but using ping in a console gives 30ms. - usually they are similar !
Pingtest/Speedtest are pinging your router. From console you are pinging a remote site. Not sure what could cause latency for pings to be asymmetric, but that seems to be what you are experiencing.
