Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
05-03-2013 7:58 PM
Quote from: Bob Don't suppose you fancy trying to find a bad gateway do you Mike?
Will try in about 30 mins,
Regards
Mike
05-03-2013 7:59 PM
Tonight:
As Jose says, the world will stop tonight, so perhaps there will be less traffic until the game is finished!
Gateway: pcl-ag06
Generally browsing seems to be acceptable so far, although the issue with the forums not always loading properly is back this evening - was ok earlier today. Jitter is a little up on normal (usually 0-1ms) but otherwise seems ok so far - I'll try again at half time!
05-03-2013 8:33 PM
05-03-2013 9:25 PM
Quote from: tonycollinet ... I meant more to ask - how often is this *sort* of issue happening. IE, how many times over the last three years has there been something similar going on?
Ah, I see. I can't answer that as I've only been with PN since late last year. Hopefully someone else will advise you.
Quote from: tonycollinet From recollection, I'd guess it was about once or twice a year when I was with plusnet, although being an old git, that could be a completely fabricated memory.
05-03-2013 11:19 PM
pcl-ag06
TBB graph still showing alot of nasty spikes during peak time - whilst this didn't impact general browsing, I'm sure it would render gaming unusable. I'm gaming tomorrow eve, so we'll see what happens then
06-03-2013 6:51 AM
Thank you and all others for last nights tests to try and get to the bottom of this problem over on the other thread where everyone worked well as a team.
I know you did not see anything that could be causing the problems at the first view of the data as it was collated late night but hopefully you and others may find something when it's looked at in greater depth.
Staying on gateway that cured my problems last night to see what happens this evening.
gateway pcl-ag05.
This is located in City Lifeline House
Don't know why but my IP dropped from 54,4 where it's been since I joined in November 2012 to 50.5 during the day yesterday hopefully it will comeback up in the next few days.
Had a good laugh last night got an email from PN asking if I'd join them with speed tests for an award. With what's happening on my connection atm they won't stand a hope of winning so I'm declining that offer just now. Concentrate on getting network running normally before awards would be a better option atm for customers than awards.
06-03-2013 8:41 AM
06-03-2013 1:11 PM
Quote from: Razer
Quote from: tonycollinet From recollection, I'd guess it was about once or twice a year when I was with plusnet, although being an old git, that could be a completely fabricated memory. Yes, I know the one ... and I'm not even an 'old git' yet. :S
Well here is the first fabricated memory - I've only been away for two years, not three as previously thought.
06-03-2013 1:54 PM
06-03-2013 1:56 PM
Quote from: tonycollinet Well here is the first fabricated memory - I've only been away for two years, not three as previously thought.
Oops. lol
Didn't have a good night last night. Managed to get four, ten-minute, lag-laden games all evening. Started with those four games on pcl ag04. Fed up with the lag, I quit for a while. Then later I hopped first to ptn ag02, then to ptn ag03, and finally, having not had any more sessions load or the game not being able to connect at all, I gave up after my last hop to ptw-ago4. By this point it was late on and so I just browsed a little and then came to watching YouTube, which by this time was running fine.
06-03-2013 4:05 PM
06-03-2013 5:54 PM
06-03-2013 7:05 PM
I'm going to be monitoring this thread tonight so please post if you are experiencing any of the aforementioned. We'll need the standard information, if you could post the information requested from yesterdays thread in here.
When/If we see a need to get data from your line it would be good if you could use IRC and let us know in real-time so we can capture this as it is happening and not to miss any vital data.
I may request in some instances that you raise a fault as we are collating and investigating this to our suppliers.
06-03-2013 7:18 PM
06-03-2013 7:39 PM
