Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
28-02-2013 3:14 PM
28-02-2013 3:27 PM
Unfortunately, as the TAP3 Results are sent onto our suppliers systems, it is likely you will see errors.
This should be resolved shortly. I am really sorry for any inconvenience this may causing you all.
Edit: - Should be up and running now
28-02-2013 4:47 PM
The latest response to my fault ticket (66179821) asked for me to connect directly to the modem to rule out the router causing the problem. Whilst I obviously want to get the problem sorted, I don't want to spend hours running tests, so I'd like to avoid anything that's pointless...
Yesterday gateway hopping sorted my speed issue, so is it really worth me bypassing the router to do a speed test or shall I reply to the ticket to say I'm running tests etc as requested by yourself and Kelly on here?
Thanks,
Ric
28-02-2013 5:18 PM
Ping:
Speed:
and finally current TBB graph:
Hopefully some progress is being made on this, although it is slightly disturbing to see this is still not acknowledged as a problem on the 'priority problems' page...
28-02-2013 5:19 PM
28-02-2013 5:29 PM
Also, is anyone else having problems with the forums? It keeps timing out on me which is just adding to the frustration! I can only post on my pc 1 in 10 times.
28-02-2013 5:31 PM
28-02-2013 5:34 PM
Quote seems to suggest this issue is not a priority
That's far from the case, if you look at the amount of time Kelly and others have put in outside of their normal 9-5.30 you'll see how committed to resolving this we are.
Can I suggest that any queries about the forum being slow are put into a separate thread so as not to confuse things in here?
28-02-2013 5:40 PM
28-02-2013 5:52 PM
28-02-2013 7:16 PM
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.67]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 12 ms 12 ms 12 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194
3 19 ms 11 ms 11 ms link14-central10.ptw-gw02.plus.net [84.93.248.12
2]
4 11 ms 11 ms 11 ms xe-10-0-0.ptw-cr02.plus.net [212.159.1.42]
5 11 ms 11 ms 11 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 11 ms 11 ms 11 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 * * * Request timed out.
9 11 ms 11 ms 35 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 12 ms 11 ms 12 ms 132.185.255.148
11 11 ms 11 ms 11 ms bbc-vip112.telhc.bbc.co.uk [212.58.244.67]
Trace complete.
C:\Users\Private>
28-02-2013 7:46 PM
28-02-2013 8:01 PM
2/28/2013 7:57 PM GMT 22.17 Mb/s 14.27 Mb/s 37 ms London < 50 mi ptw-ag02
Turns out it does affect me after all
Manually disconnecting/reconnecting to a different gateway was an instant fix.
28-02-2013 8:03 PM
Looking good so far. Fingers crossed this lasts throughout.
28-02-2013 8:04 PM
