Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
21-02-2013 11:44 PM
22-02-2013 12:21 AM
22-02-2013 5:34 AM
pcl-ag05 (20CN connection)
Edit: back to normal , ptw-ag04
Regards Mike
22-02-2013 9:30 AM
22-02-2013 2:00 PM
Quote from: I Last night was not to bad, but at 5.30am this morning its the worst it has even been, what could be causing this as obviously this is not peak time?
There was bt maintenance this morning which could have caused it.
Ex-Plusnet Jobsbody
22-02-2013 2:22 PM
Regards Mike
22-02-2013 4:54 PM
22-02-2013 5:27 PM
22-02-2013 8:18 PM
22-02-2013 8:28 PM
Ex-Plusnet Jobsbody
22-02-2013 8:46 PM
22-02-2013 8:58 PM
I'm currently getting pings to the servers I normally play Tf2 on over 700+ which are normally stable 24ms.
I hope you can sort out the issues soon and will continue to keep disconnecting until I connect to a better
gateway than:-pcl-ag05.
Which gateway
You are currently connected to the gateway known as pcl-ag05.
To Server Maidenhead 51mls
Ping test gives Plusnet an F 206ms ping 81% Packet loss 66msJitter
Not great.
ntp.plus.netMicrosoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights
>ping ntp.plus.net
Pinging ntp.plus.net [212.159.6.10] with 32 bytes of
Reply from 212.159.6.10: bytes=32 time=154ms TTL=246
Reply from 212.159.6.10: bytes=32 time=133ms TTL=246
Reply from 212.159.6.10: bytes=32 time=142ms TTL=246
Reply from 212.159.6.10: bytes=32 time=119ms TTL=246
Ping statistics for 212.159.6.10:
Packets: Sent = 4, Received = 4, Lost = 0 (0% los
Approximate round trip times in milli-seconds:
Minimum = 119ms, Maximum = 154ms, Average = 137ms
It's so rubbish at the moment I hope it gets better.
22-02-2013 9:12 PM
Quote from: kareha What is generally the best gateway to be on in case of having to switch around?
It seems to be a bit hit and miss at the moment. You can't choose a gateway anyway, you just have to hop and hope you get one that's good for you.
22-02-2013 9:15 PM
Try pinging ntp.plus.net. That way you aren't influenced by factors outside your connection to Plusnet and the Plusnet network.
Also ping bbc.co.uk is another good one to try, but that of course goes out to the beeb.
22-02-2013 9:34 PM
