Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
14-02-2013 12:53 PM
14-02-2013 12:53 PM
Ex-Plusnet Jobsbody
14-02-2013 12:54 PM
Ex-Plusnet Jobsbody
14-02-2013 1:00 PM
Quote 1 192.168.2.1 (192.168.2.1) 164.334 ms 1.573 ms 1.553 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 159.495 ms 174.986 ms 149.578 ms
3 link9-central10.ptn-gw01.plus.net (84.93.248.240) 35.647 ms 131.177 ms 36.276 ms
4 * xe-10-1-0.ptw-cr01.plus.net (212.159.1.44) 155.770 ms 37.203 ms
5 ae2.ptw-cr02.plus.net (195.166.129.5) 34.696 ms 34.088 ms 40.077 ms
6 ae2.ptw-cr01.plus.net (195.166.129.4) 36.142 ms 38.760 ms 37.922 ms
7 kingston-gw.thdo.bbc.co.uk (212.58.239.6) 35.981 ms 38.403 ms 34.650 ms
8 * *
I'll just use my BT connection until you get this sorted as it's annoying having it work perfectly for short periods and then having to break off and spend time finding a working gateway.
14-02-2013 1:16 PM
And now....? Slow? Laggy?
The traceroute doesn't really tell us anything because the end hop isn't shown. The peak on the second hop is probably because the gateway is busy routing and responding to a traceroute isn't top priority.
Ex-Plusnet Jobsbody
14-02-2013 1:21 PM
SkyGO, wouldn't display correctly - it was pixelated and voice was delayed, when I first switched onto ag04 it was smooth and crystal clear.
Browsing, was just slow in general.
This is the complete traceroute:
Quote traceroute to bbc.co.uk (212.58.241.131), 64 hops max, 52 byte packets
8 * * *
9 ae1.er01.rbsov.bbc.co.uk (132.185.254.46) 37.634 ms 35.003 ms 35.165 ms
10 132.185.255.60 (132.185.255.60) 38.769 ms 44.813 ms 35.374 ms
11 virtual-vip.thdo.bbc.co.uk (212.58.241.131) 44.615 ms 35.391 ms 34.962 ms
14-02-2013 2:37 PM
14-02-2013 5:40 PM
14-02-2013 5:56 PM
Have you tried setting up some form of QoS on your router (if you can) to prioritise services like Skype etc?
There is a difference with TBB graphs and pingtest.net - TBB pings your router whereas pingtest.net tests from a machine inside your internal network. I found pingtest.net unreliable at times so stuck with command prompt and ping/pathping commands.
14-02-2013 6:05 PM
I did the pingtest check after I ran into problems with Skype, as I wanted an instant check which TBB won't give me, and the results seemed to confirm that there were problems on the line at the time. Also, the BT speedtest (part 2) refused to complete, and doesn't that also go from the router (could be wrong here)?
Just FYI, all tests (and Skype) are carried out from a PC which is wired via ethernet cable to the router.
scratches head
edit: forgot to mention, don't think my router (Netgear DG834PN) has QoS.
14-02-2013 8:00 PM
14-02-2013 8:14 PM
Ex-Plusnet Jobsbody
14-02-2013 8:17 PM
15-02-2013 5:31 PM
15-02-2013 6:09 PM
Ex-Plusnet Jobsbody
