Peak time latency spikes
Finguz
Re: Peak time latency spikes
Sad
Test 3 continues to fail  Lips_are_sealed
Anotherone
Champion
Fixes: 21
So what happened when you clicked the "Continue" button ?
Chris
Legend
Fixes: 169
Anyone still experiencing issues it would be really helpful if you could start your own threads in Broadband and Routers now, this one has got a bit unwieldy and whilst it contains a lot of useful information it'll be easier for us to look at the remaining few problems separately (while keeping this thread in mind of course).
Pettitto
Fixes: 5
@Finguz
I've taken a look into your line and we'd like to get an engineer out to take a look at things for you.
We're just working with our suppliers so that we can do just that. We'll keep you updated via your Fault Ticket.
Finguz
I had an engineer here just about a week ago? No faults were found of any kind.
But yeah, whatever it takes is fine with me.
Finguz
Quote from: Anotherone
DNS fails.
If I use the IP address it times out.
I have tried manually entering DNS, auto assigned DNS and everything else in between with the same results. We have also tried 3 different pc's, a laptop and two other routers.
Tbh I'm fed up with trying to fix BT's broken Tap3 test  Crazy
jamesanstee
After a good week with stable speeds the speed is now starting to go bad again
englishrick
Your ping is high, mine is almost that for some unknown reason...and the same old story with peak time for me..Hopefully Chris Pettit and Kelly will have some luck getting BT to pull their fingers out...and get it sorted ASAP
dick:quote
jamesanstee
I had noticed that since being put onto the elevated product my line profile has dropped by 10Mbps . and also affected the upload speed.
dick:quote
AndyH
How are speeds now?
Which gateways are you on?
jamesanstee
Im on gateway ptn-ag03 speeds are now down to half of what i should be getting bt wholesale speed tester is failing to complete when i send results to server it keeps coming back with an error 500 page.
AndyH
Their checker is fubar.
You need your broadband circuit ID to get to the next page I think.
Finguz
Pcl-ag07
jelv
Fixes: 10
Quote from: Chris
Suggestion: Posts are split out from here to new topics with a single linking post in here.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Jaggies
My first peak time usage for over a week - currently on gateway ptw-ag03.
Speedtest now:
Speedtest 50 minutes earlier:
What I usually get...
So ping and upstream unaffected, just a significant downstream drop still.
