Peak time latency spikes
Phileasfrog
Re: Peak time latency spikes
I rejoined PN last week after some years with Idnet with whom I had 80/20 fibre.  I only left because of cost  - the performance / support was excellent......  However since rejoining PN last week, apart from one dire night when my 78mb download slipped to 10mb, PN has been fine, except for the latency issues during peak times (I am currently on ptn-ag02 gateway):
NB  I was not using the internet at all during the peak time in the graph.
There seems to have been discussion about whether the problems lie within the PN, or the BT infrastructure, however the latency issues have only commenced for me when I joined PN, and Idnet make great play about having absolutely no contention within their own network.  My (simple?) conclusion is that the problem does lie within the PN network, and not BT as has been suggested.
Anotherone
Champion
Fixes: 21
@Bright
You left ptn-ag04 out of the list  Wink
Bright
Oops!  Embarrassed
MrRichThomas
Fine at the moment, I'm still on PCL-AG02.
Edit: speedtest link seems to be broke but it was :
Ping: 9ms
Download Speed: 70.46Mbps
Upload Speed: 16.80Mbps
Bright
Gateway pcl-ag05
Everything looking normal at the moment.
austinsom
Speeds alreay a little down:
Pingtest shows pings as being just fine as of now:
However, TBB graph is showing some high latency peaks already - have to see how it fares for the evening:
My current gateway is pcl-ag01, which has had mixed performance from what I have seen - fingers crossed  Undecided
MsDizzie
Gateway: pcl-ag08
ADSL2
Just browsing but RouterStatsLite has been having a fit from 4:30pm onwards
And its still on going... pinging only to ntp.plus.net
Using Exchange Checker its all green lights (last checked 8th Feb 2013)
Is there any other info you guys need?
*Edit* improvement at 7:30pm (see 3rd file)
MrRichThomas
Still fine here on pcl-ag02, hope it stays like this as Friday night is Halo 4 night.  Smiley
austinsom
Performance has degraded significantly - 5Mb lost over usual speeds, pings up and TBB graph looking erratic. Still on pcl-ag01.
^ Not looking good...  Cry
ricmelia
ptw-ag02. still fine tonight
(speedtest done with iplayer streaming radio to squeezebox, probably explains the ping)
picbits
I've gone from 65Mb down and 18Mb up to 8-10Mb down and 8-15Mb up this evening.
Ping has also gone from 5ms to 30ms+
Line speed is still 69.5Mb and I was getting a nice solid 65Mb download speed earlier.
*edit - getting slower .......
*edit - just found the gateway test tool after a bit of searching - about to kill my connection and reconnect ....... currently on  ptn-ag03
MrRichThomas
Quote from: MrRichThomas
Big fall in the last hour....  Sad (will do another at 9.30)
jamesanstee
Still suffering the slow speeds even though plusnet made some adjustments to my line its not made any difference
I'm currently connected to gateway pcl-ag03.
picbits
I've just done a disconnect / reconnect and speed is back to normal - reconnected on PTN-AG02
lurcher
Hi, new to forum but have been suffering low speeds in evening and back to normal in morning ever since unlimited was launched,
raised ticket but this problem was not mentioned in the reply from Plusnet.  Then saw this topic on forum.
tonight, was running at 1.6mb instead of 4.9, I was on pcl-ag01, disconn / reconn put me on plc-ag07 this dropped speed to 0.6mb  Embarrassed
disconn / reconn again to ptn-ag02 now back to 4.7MB. Smiley
I was told I could have a problem at my end, doesnt look like it
