Peak time latency spikes
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
19-02-2013 10:04 PM
Download Speed
0.06 Mbps
0 Mbps 68.23 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.06 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-68.23 Mbps .
Additional Information:
IP Profile for your line is - 68.23 Mbps
Upload Speed
0.04 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 0.04Mbps
19-02-2013 10:06 PM
Usually when I run a ping test using - http://www.pingtest.net/, the program pings a load of servers and then proceeds to do a jitter test using the server with the lowest ping.
Normally the lowest pings (for me) come from one of about five sites in London - which seems logical because London is my nearest major gateway. However tonight when I use this program, the pings returned in London (and presumably the rest of England) are so high, that I am getting lower pings from servers in different COUNTRIES !
The lowest ping I can get in London is 102ms, whereas Dublin is returning 59ms, and least jitter from Norway !
What the hell is going on ?
If there is less latency from foreign servers, then is this bottleneck in Plusnet gateways or in the main BT trunks across England ?
19-02-2013 10:09 PM
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.93]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 11 ms 11 ms 10 ms lo0-central10.pcl-ag04.plus.net [195.166.128.185
3 11 ms 10 ms 10 ms link3-central10.pcl-gw01.plus.net [84.93.249.100
4 10 ms 10 ms 10 ms 52.core.plus.net [212.159.1.52]
5 10 ms 10 ms 11 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 10 ms 10 ms 11 ms ae2.ptw-cr01.plus.net [195.166.129.4]
7 28 ms 11 ms 11 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
8 * * * Request timed out.
9 11 ms 11 ms 11 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10 12 ms 12 ms 12 ms 132.185.255.165
11 12 ms 11 ms 11 ms bbc-vip014.cwwtf.bbc.co.uk [212.58.246.93]
Trace complete.
C:\Users\Private>
19-02-2013 10:40 PM
And now suddenly, ping times are back to normal !
19-02-2013 10:44 PM
Not for me connection is barely usable . And im connected to the gateway known as pcl-ag04.
Quote from: purleigh And now suddenly, ping times are back to normal !
19-02-2013 10:48 PM
Purleigh: What gateway are you on?
Ex-Plusnet Jobsbody
19-02-2013 10:50 PM
19-02-2013 10:50 PM
19-02-2013 10:57 PM
Ex-Plusnet Jobsbody
19-02-2013 11:08 PM
Does it involve a free upgrade to "Max Premium" - to get the most from my 20CN line on a never to be upgraded 'Market 1' exchange ?.
PLEASE ?
PRETTY PLEASE !
19-02-2013 11:11 PM
jamesanstee: Sorry dude
Ex-Plusnet Jobsbody
19-02-2013 11:16 PM
19-02-2013 11:17 PM
Ex-Plusnet Jobsbody
19-02-2013 11:25 PM
19-02-2013 11:25 PM
Yes I have still have full speed, and pings have returned from >100ms, to about 40ms (rather than the 23ms I used to have) - which you said is due to interleaving having been applied to my connection.
Is my line stable enough to have interleaving switched off ? - my router shows maybe one or two CRC errors per day.
