New View My Broadband Usage layout
jelv
Fixes: 10
Re: New View My Broadband Usage layout
Quote from: mexicano
Can I add my two cents worth? Is it possible to move aside the right hand column that starts: Please note: Your usage includes....... On my screen this column overlaps the total usage. Is it me and what can I do to fix this?
CTRL+0 to return your display font to the normal size rather than the 120% which you have set at present will cure it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
even my little netbook with the program bar at the left handle it ok
mexicano
Hi Jelv,
Did as you mentioned but still the same, no change. I use nosquint add-on extension which I also disabled but still nothing except the text is smaller Smiley
Also clicked on View,Zoom and Reset and that did nothing either. And an other member, PlusCom, has the same problem.
PlusCom, has your window gone back to normal after doing the reset from Jelv?
Quote from: jelv
Hi Jelv,
No it doesn't, I'm already on the minimum font size I want.
Apple iMac key shortcut wouldn't work anyway.
jim:green quote fixed mod:end
pierre_pierre
next question then what browsers are you using, and what operating system, I m using Win 7 and firefox with no problem
Apple 10.6.8
Zoom and minus zoom
Works on Firefox 6 and Chrome (I rarely use either of those)
Doesn't work on Safari or Camino (my default browser)
The table stays the same size, the RHS alters
It can be made compatible for all browsers by just moving the RHS menu
mexicano
Sorry took so long to reply, been out in the sunshine Smiley
I'm using Windows 7 Ultimate and Firefox 5, and before you ask, it was the same on FF 4
But when you asked about which browser I'm using I decided to try my IE 8 and the "This Month in Details" page is OK. with no overlapping. My problem is just with Firefox. I've also started Firefox in Safe Mode with all add-ons disabled and still the same!!  Crazy
Oldjim
Resting Legend
Fixes: 63
Window 7 64 bit Firefox 5 and no problems.
Are you using an adblock or similar addon as adblock plus shows quite a number of blockable style items
mexicano
Hi Oldjim. As I mentioned before I disabled all my add-ons and went into Safe Mode but it didn't make any difference. I am using ABP but I have just disabled it on it's own but still nothing.
jelv
Fixes: 10
Can you do another screen dump after resetting the font size (you need to check it doesn't still say 120% at the bottom right). I'm wondering if after resetting the font it needs a refresh to repaint the screen.
Oldjim
Resting Legend
Fixes: 63
Replicated it - see picture
This is how I did it - see second picture
mexicano
Mine is still the same after-starting FF. I also tried Zoom Text Only but nothing.
Oldjim
Resting Legend
Fixes: 63
I needed to untick zoom text only to get it back
mexicano
Did it both ways, ticked and unticked
Oldjim
Resting Legend
Fixes: 63
Looking at your picture you seem to have modified chrome.css to get the bold font in the tabs
Have you installed a style using stylish
