Launch of new Plusnet Fibre Products - 80/20 and 250GB usage allowance
vinnym70
Re: Launch of new Plusnet Fibre Products - 80/20 and 250GB usage allowance
Quote from: Bob
Quote from: vinnym70
If I try a product change, I don't seem to be able to alter what I'm offered.
Already on Extra Fibre and on the 80/20 trial. Does that imply an automatic upgrade to the new package?
I'm guessing I have to do something otherwise I'll be put back to 40
Hmmm, taking a look into this now. I know it's been possible for others though Huh
This is the problem. From here:
[quote author="BT Wholesale Availability Checker"]Your cabinet is planned to have WBC FTTC by 30th September 2012. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 72.1Mbps and upstream line speed of 20Mbps.
Notice anything slightly contradictory in that statement? It's confusing our account change logic. We can change your account manually for you if needs be?
Hmmm. The BT checker has been like that, on-and-off, since FTTC was available for my locality. Nice work spotting that one though!
On the basis that date will just slip and slip, if you can do a manual change I'd appreciate it.
KevinG
I would be intrigued to see whether a move from the trial to the official 80/20 product through the standard link causes a DLM reset. That could increase speeds for some, at least for a while.
houlton23
@KevinG
I have the following two tickets on my account following an account change this morning (trial --> Extra Fibre), which seem to suggest PN have sent the order anyway as the system is assuming I'm on 40/2. Whether the order will be rejected by BT because our line is already provisioned on 80/20 or not remains to be seen.
Provisioning of your ADSL Account Information
New Action 21CN Modify Submitted added
(via ADSL2+ Order System Interface)
Pending Provisioned Service \'WBC FTTC Annex A 20Mbit/s Up, 80Mbit/s Down, Standard Stability\' added as a part of Account Change process
Alex Smiley
bobpullen
Fixes: 327
If you can do a manual change I'd appreciate it.
Leave it with me.
Quote from: KevinG
No it shoudn't do. If the system generates a modify order it will fail because none of your line characteristics will be changing.
KevinG
Thanks Bob, that makes sense. Not really an issue for me at the moment as I'm almost at the fastest I've ever had.
bobpullen
Fixes: 327
Quote from: Bob
Leave it with me.
Done.
vinnym70
Very kind - appreciate the help!
jim:quote
KevinG
Looking at the new products it does seem a bit odd that Value Fibre customers, for the same price, get an increase in upload speeds but no extra usage allowance, whereas Extra Fibre customers get an increase in download and upload speeds and a more than doubled usage allowance for £1.50/month less. An increase to 80GB for Value Fibre would have balanced things a bit.
bobpullen
Fixes: 327
Existing Extra Fibre customers get the upload uplift too (assuming they don't move to the new 76Mbps Extra Fibre product of course).
If we increased Value usage then I'd imagine we'd see a decrease in the number of customers converting to Extra. There's only £3.50 in it and anyone wanting more usage is welcome to upgrade. Don't forget too that Value customers get their speed uplift automatically whereas Extra customers need to pro-actively request the change to the new product. With the exception of the 80/20 trialists, Extra customers are also re-contracted when they're switched across.
w23
Fixes: 4
Done mine - too good not to!  After the end of this charging period I can probably let the kids do what they want (streaming) without having to keep nagging at them not to 'waste the bandwidth'.
Do I need to do anything (as an 80/20 trialist) to avoid being re-contracted (not that I'm looking at moving anyway with such a good product enhancement)?
Nice one PlusNet!  Smiley Smiley
Call me 'w23'
Oldjim
Resting Legend
Fixes: 63
Bob,
I little clarity required.
I think that this is the situation - please correct me if I am wrong
Quote from: Bob
Don't forget too that Value and Extra customers get their speed uplift to 10Mb automatically whereas Extra customers need to pro-actively request the change to the new product. With the exception of the 80/20 trialists, Extra customers are also re-contracted when they're switched across.
When will I get my free upload speed increase?
We’ll be increasing all existing fibre customers’ upload speed from 1.9Mbps to up to 9.5Mbps for free. The upgrades will happen over several weeks beginning 14th September.
http://community.plus.net/8020-fibre-faq/#12
bobpullen
Fixes: 327
Quote from: walker23
No. The upgrade journey will assume you're re-contracting but we'll be running reports here to adjust the contracts on 80/20 trialists once they're moved across.
@Oldjim
All fibre customers will have their upload increased to 'up to 9.5Mbps' without having to do anything. Old Extra Fibre customers wanting to move to the new Extra Fibre product (with 'up to 76Mbps' speeds and 250GB usage) need to request the change via our website and re-contract (unless an 80/20 trialist).
[Moderator's note by Jim (Oldjim):  Full quote of preceding post removed, as per Forum Rules ]
kingkobra
Hi. Looks like it might be time to get serious about swapping to fibre.
Just one question. The line checker says I will get an estimated speed of 33.1 Mb/s. Does the 76 Mb speed require additional infrastructure changes to support it? Just wondering if that is the max speed, or if a change at the exchange will enable 76 Mb at some point in the future.
Cheers!
Oldjim
Resting Legend
Fixes: 63
The speed you will get is dependent on the line length from you to the cab - you have to be fairly close to get the maximum speed
http://www.thinkbroadband.com/guide/fibre-broadband.html
Picnic
Almost completed the request to switch to the new fibre extra from the old. However I am a phone customer of yours and took advantage of the pay the line rental upfront for 12 months. My old products listed
Line rental £0.00
while the new says
Line rental £12.99
Can we assume the system is clever enough to realise the line rental is already paid for or am I going to get charged a 2nd time?
Also being a trialist on the 80/20 system your speed estimations are very optimistic. 61/20 estimated, I struggle at around 50/10.
