Launch of new Plusnet Fibre Products - 80/20 and 250GB usage allowance
- News & Announcements
- Community Announcements
- Launch of new Plusnet Fibre Products - 80/20 and 2...
Re: Launch of new Plusnet Fibre Products - 80/20 and 250GB usage allowance
24-08-2012 11:38 AM
Quote from: Chris The pages have now been updated:
You should probably trumpet this from the rooftops a bit! Makes the Pro add-on a bit lame though ...
24-08-2012 11:47 AM
24-08-2012 11:48 AM
Also, if we do have some congestion at peak hours, and your game isn't identified, you might see it suffer. Pro would mean it would work fine.
Ex-Plusnet Jobsbody
24-08-2012 11:51 AM
Does Pro do anything else in terms of prioritising traffic? Otherwise as KevinG noted £5 for faster speeds for only 2 hours a day isn't such a good deal any more!
James
[Edit: Kelly managed to answer before I clicked on the post button!]
24-08-2012 12:59 PM
24-08-2012 1:47 PM
Quote from: KevinG Makes the Pro add-on a bit lame though ...
I agree with that (but didn't like to say). What's really happened, though, is that the base products have improved so much that 'Pro' is simply less necessary but it's still available or those who want to remove all throttling.
24-08-2012 1:59 PM
Router just arrived. Thanks again.
Quote from: Chris I've just looked and for some reason the order hasn't submitted, I've placed it manually now for you so that should be with you in a day or so. We're also checking to see if anyone else if affected.
24-08-2012 6:50 PM
With these changes though, I'm seriously tempted to remove it and see if I even notice.
24-08-2012 10:28 PM
Quote The pages have now been updated:
http://www.plus.net/suppo...ide/download_speeds.shtml
http://www.plus.net/suppo...roadband_experience.shtml
I said it a few pages back, and I'll say it again: This just gets better and better!
25-08-2012 12:16 AM
25-08-2012 9:43 AM
And this time (compared to the trial, which was an epic failure for me) it has worked!
Going to cancel my Pro add-on as it's now completely useless to me! good job I checked here or I wouldn't have known I was wasting £60 a year.
25-08-2012 12:47 PM
25-08-2012 1:33 PM
i do have a question though, arent we supposed to be up to 20mbps uplaod ?
if we are mines says 10mbps max attainable speed - using BT speedtester
Download Speed
19.02 Mbps
0 Mbps 24.47 Mbps
Max Achievable Speed
Download speedachieved during the test was - 19.02 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-24.47 Mbps .
Additional Information:
IP Profile for your line is - 24.47 Mbps
Upload Speed
6.57 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 6.57Mbps
Upstream Rate IP profile on your line is - 10 Mbps
25-08-2012 1:37 PM
Quote from: momsieden arent we supposed to be up to 20mbps uplaod ?
PN put you on 40/10 if your line estimate is below 40Mbps, as there is no benefit to you and it costs PN more per month.
25-08-2012 2:09 PM
i wasn't aware of that
