Get your names in quick - YouView Trials
hex
Re: Get your names in quick - YouView Trials
Same here on the router - still have my tg582 in its box as a backup if really needed.
But I would imagine part of the trial will be testing the various customer setups and if needed basic configuration information will be provided, even if it is not officially supported (as for the normal broadband service).
snozski
I signed up on the 19th when I saw from the blogpost via RSS feed.  Not had any email from them though ! Sad
VileReynard
Fixes: 20
If they want to charge extra for some rubbish football channels, Plusnet won't want any old router picking up their broadcasts.
hex
Why would that make any difference?  I assume the service is linked either to the line or the viewing box so other than for support purposes I doubt they care what router is being used.
AndyH
Not all routers work with or support multicast/IGMP proxy. There is a list on the Infinity forums of which ones are proven to work etc - https://community.bt.com/t5/YouView-box/Known-Routers-to-Work-with-Multicast-IGMP/td-p/994338
TLE
Here is my understanding of the issues with 3rd party routers. Most routers support multicast and IGMP, the one thing that a lot of home routers don't support is 802.11Q on the WAN port which is required for BT's multicasting. The router must be able to accept traffic on a specific VLAN on the WAN port in order to receive the multicast channels.
There is a sticky on the BT forums for which routers do and don't work.
https://community.bt.com/t5/YouView-box/Using-a-3rd-party-router-for-Multicast/td-p/1048582
jim:green link fixed mod:end
KevinG
Define "third party router". Plusnet has supplied a number of routers; I have two supplied by Plusnet for FTTC, neither of which is a TG582n.
NorthEasterner
Were they netgear?
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
VileReynard
Fixes: 20
Netgear was one of them...
bluewhale
Quote from: NorthEasterner
Were they netgear?
i still have the wnr2000v2 from the fttc trialling, anyone know if it works?
KevinG
Were they netgear?
I got a Netgear and a ZyXEL.
NorthEasterner
Below is a list of all the routers / modems supplied by Plusnet.  Some are ancient!
Zyxel Prestige 660H 4-Port Router
Zyxel prestige 2002 VoIP ATA
Netgear WNR1000
TG585
Speedtouch ST-516
Speedtouch 716WL
BT Voyager 105
BT Voyager 205
BT Voyager 210
BT Voyager 240
BT Voyager 2091
BT Voyager 2100 / 2110
1800 HG Intelligent Gateway
2205 4 port wired router
2100 4-port wired router
ADSL 500 USB modem
DSL 320B Ethernet Modem
DSL-2640B 4-port wireless router
USB Modem
A360 USB Modem
SAR900 USB Modem
SAR110 wired router
SAR130 wired router
3COM 4-port wired router
Alcatel 1-port wired router
KevinG
I can add the ZyXEL NBG4604 to that list.
Jcook76
Any idea when those chosen for the trial are likely to be notified?
Thanks.
picbits
It has been said earlier in the thread "within a few weeks"
