E100 Wireshark Trial - what's all this then?
- News & Announcements
- Community Announcements
- E100 Wireshark Trial - what's all this then?
Re: E100 Wireshark Trial - what's all this then?
07-06-2012 5:29 PM
@jelv - Thanks, I'll check that that's all correct with Dave and Denis.
@aerodiver - it's possible, certainly hope it's not as a result of this though. We'll keep an eye on things.
07-06-2012 6:12 PM
Edit: OK, tracked most of it down. It's because Win 7 has enabled IPv6 on the connection and most of the IPs are my own.
07-06-2012 8:39 PM
Quote from: aerodiver Just had a connection dropout, and reconnect. Router lost IP address temporarily.
Looks like it could be a 'setting-up' disconnect or something?
Anyway all looks good so far, tried a couple VPN's, set up a TBB BQM:
Alex
07-06-2012 8:47 PM
07-06-2012 9:01 PM
Has the spotify 'p2p' streaming issue become fixable with these new traffic management switches? Just checked and I *think* it's coming down as Silver (0x40)?
Quote from: dave Doesn't look it's going to be possible unfortunately to pick up the P2P element of Spotify and classify it separately. Any content delivered direct from Spotify is already built in as streaming but we can't add the P2P element.
Alex
08-06-2012 8:53 AM
08-06-2012 9:09 AM
Is there any explanation for the 4 drops me and jelv's connections saw last night?
Alex
08-06-2012 9:51 AM
I'm on ptw-ag02, which gateway are you on Alex?
08-06-2012 10:21 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13391471567664.png" />
And jelv's:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13391472589611.png" />
As per the above we've not seen any drops from our side of things.
08-06-2012 10:25 AM
And I'm on ptw-ag03.
Alex
08-06-2012 10:29 AM
08-06-2012 11:14 AM
What issues are people facing with Spotify?
08-06-2012 11:19 AM
There was a thread on this a couple years back here but the conclusion was that because Spotify uses encrypted P2P, the traffic management switches couldn't pick up that traffic properly and put it in the Gold (or streaming) queue.
It doesn't cause too much of an issue on most accounts, but on accounts where P2P and Other traffic are heavily rate limited (to below the 160kbps Spotify Free streams at, or the 320kbps for Premium for example), it can cause issues (P2P on the legacy Unlimited package is rate limited to 128kbps and Other to 228kbps between 6-10pm)
08-06-2012 1:28 PM
Right... correct graphs then
houlton23:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1339158358651.png" />
jelv:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13391583781525.png" />
Hope that's a bit better. The blips at the start of houlton23s are the connections that didn't work (as I mentioned above you'll only be able to connect 1 in 5 times) so nothing to worry about.
08-06-2012 3:12 PM
