E100 Wireshark Trial - what's all this then?
- News & Announcements
- Community Announcements
- Re: E100 Wireshark Trial - what's all this then?
30-05-2012 2:22 PM
31-05-2012 12:00 PM
I use a couple of different VPNs, a mix of corporate and consumer grade stuff as well as various ssh connections and tunnels for remote access at home. (I have a fast mobile broadband connection as backup in case this all goes pear shaped!).
I also do some PS3 gaming, and a limited amount of PC gaming but I do play a fair bit of online poker - a more rewarding online gaming experience
I know my way around wireshark so happy to give this a try if this kind of profile would be helpful.
Kind regards,
Paul
31-05-2012 1:51 PM
We'll let you know as soon as we have some usernames and stuff.
31-05-2012 2:52 PM
Quote from: aerodiver (I have a fast mobile broadband connection as backup in case this all goes pear shaped!).
Not needed! If it goes wrong you just revert to your normal login.
31-05-2012 3:51 PM
Quote from: jelv Not needed! If it goes wrong you just revert to your normal login.
Even better!
02-06-2012 5:27 PM
play PS3 games Pc games and some streaming
06-06-2012 11:07 PM
07-06-2012 10:46 AM
Really sorry for the delay, everything is now in place and I'll be dropping you all a PM with the usernames and passwords of your trial accounts shortly.
Also, just wanting to give you a heads up - we will shortly (as in today) be announcing that we're moving some live customers onto the new platform by the means of virtual routes on certain gateways.
Please, please don't think that this either means that we've rushed things and haven't tested, or even worse that there's no point in you guys doing this. There absolutely is.
As I said in my initial post, we've got by far the majority of traffic signatures on there. As with the current E30 platform there'll always be one or two tricky protocols that haven't been picked up - possibly one or two more in this case as we can't catch everything (though we've got what our staff could). Any traffic that is not behaving properly we'll need a wireshark capture file for, which is what we're hoping you guys will be able to provide - this will then let us improve the experience with everyone. Even after this platform has gone fully live we're hoping that you'll still be willing to do a quick capture if something's not working (plus of course you get the extra usage on these accounts as dsw mentions
Right I'll sign off there and start sending PMs. Once again, thanks very much.
07-06-2012 10:50 AM
Will those customers be informed or is there a list of gateways which are being moved.
Quote from: Matt Also, just wanting to give you a heads up - we will shortly (as in today) be announcing that we're moving some live customers onto the new platform by the means of virtual routes on certain gateways.
The reason for asking is that where a poster suddenly finds something isn't working as it used to it is one thing to check.
Would a tracert show the change as a different routing
07-06-2012 11:30 AM
Quote from: Oldjim Will those customers be informed or is there a list of gateways which are being moved.
The list of gateways is on the service status post.
Quote from: Oldjim The reason for asking is that where a poster suddenly finds something isn't working as it used to it is one thing to check.
In all honesty I'd be very surprised if anyone came across something not working
Quote from: Oldjim Would a tracert show the change as a different routing
I don't believe so, no - the ellacoya switches are transparent on a traceroute so it'd still show the gateway and then the next hop as it does now.
07-06-2012 1:16 PM
By retry I don't mean resync
07-06-2012 1:47 PM
07-06-2012 2:28 PM
I've wiresharked connecting and using the VPN and everything came in as x80.
07-06-2012 2:57 PM
Promise to settle down into a bit of work soon to check out the various VPNs & tunnels (rather than spend the afternoon on the PS3 or playing poker!), will let you know if I spot any issues.
07-06-2012 3:03 PM
Teething issues?
