E100 Wireshark Trial - what's all this then?
- News & Announcements
- Community Announcements
- Re: E100 Wireshark Trial - what's all this then?
16-05-2012 4:34 PM
We're currently in the process of upgrading our traffic management platform (from E30's to E100's, for those interested).
This means we'll need to recreate a lot of the traffic signatures for the platform. This is where you (hopefully) come in.
We'd like some volunteers who are comfortable using wireshark and who ideally use a large number of different protocols - games especially. These volunteers will be moved over to the new platform ideally on Friday.
Basically you'll need to use the connection as you normally would and if you notice anything running slowly take a wireshark capture. We'll be getting you a link to raise a ticket to a dedicated pool with these capture files attached, so Dave can create the signatures needed - we'll let you know what that is when we've got some volunteers ready.
More information will of course follow but if you're interested please drop a post in this thread and we'll be in touch.
EDIT: It's important to state that you shouldn't really consider this trial if you need your connection working as fast as possible. Some rules we'll be able to turn around quite quickly but others may take a few days or even weeks depending on how complicated they are. If you use a VPN and it's essential for work then this is not recommended for you, though if it's a backup connection and you don't mind testing VPN software on it then please do consider it
If you don't mind that then please do volunteer as this will be an immense help.
16-05-2012 4:59 PM
16-05-2012 5:06 PM
Cheers for the heads up, should have thought to mention that.
16-05-2012 5:18 PM
PeteB
16-05-2012 5:26 PM
22-05-2012 12:11 PM
I can give it a go for you, main games are racing sims / fsx / some VOIP.
23-05-2012 8:52 AM
23-05-2012 8:55 PM
24-05-2012 8:52 AM
Right, that more information.
The experience won't be as bad as I've made it sound. We've already got rules for most things, we're just asking for people to go on the trial and use their connections as they normally would so we can pick up the last few bits - games in particular, but also anything else that may have a lot of different protocols or that isn't perhaps quite so widely used.
We'll also make sure you get a trial login for this (username and password for the router) so if you do encounter any issues you can run the wireshark and then log back in with your regular account details and everything will work as it does currently.
Hope that persuades one or two more, thank you for reading
24-05-2012 9:01 AM
28-05-2012 7:38 PM
29-05-2012 5:12 PM
Yes, it's definitely going ahead - the trial accounts are being created now, sorry for the lack of updates.
If it's an incentive to any others who've considered applying, bear in mind usage whilst on the trial will count towards a different account and not your own so for all intents and purposes trial usage is free.
I'm also in the process of negotiating some kind of thank you gesture for coming on the trial, likely to be in the form of free Pro (if that's viable) or a similar equivalent if that tempts anyone further?
We really need help on this one, everyone
dsw, PeteB and picnic we'll be in touch with details of what's happening and how to help tomorrow, many thanks. Of course the above applies to you guys as well.
Thanks for reading, all.
29-05-2012 6:41 PM
Must have missed this thread for some reason, but I'd be willing to give it a go if it helps PN out
80/20 trial line here syncing at the max so should be able to help.
If we don't find any problems do you want reports of what is working properly too?
Alex
30-05-2012 9:05 AM
It'd be nice to know generally if things are working but most things have been captured so please don't feel you need to list everything that works - it's mostly games we're after really, and other sort of 'niche' protocols that aren't widely used. Some of our staff are on the trial so that's helped, but different people will use different things and that's kind of what we're banking on here to make sure everything is in place.
30-05-2012 10:16 AM
