BT Speedtester - 3 hour time lock relaxed
- News & Announcements
- Community Announcements
- BT Speedtester - 3 hour time lock relaxed
11-02-2010 3:39 PM
Might be of interest to some.
Just stumbled across this from a recently circulated BT Wholesale briefing. It's effective immediately AFAIK:
[quote author="BT Wholesale"]The time restriction on the BT Wholesale broadband performance tester has been reduced to 1 hour.
Time Limit Between Successful Tests
To protect the performance tester platform a 3 hour time limit between successful tests was introduced. This was to prevent a number of end user from continually running repetative tests which was causing service degradation for all.
We are pleased to inform you that this restriction has been reduced to 1 hour between successful tests. If the original test is unseccessful the End User will be able to run repeat tests until a successful test is achieved.
Message 1 of 2
(8,381 Views)
1 REPLY 1
Re: BT Speedtester - 3 hour time lock relaxed
11-02-2010 3:59 PM
Thanks Bob
Shutter noticed the change also http://community.plus.net/forum/index.php/topic,83361.msg686366.html#msg686366
Message 2 of 2
(1,143 Views)
