Within...?
Teatime
Within...?
The description of this section says "please read the disclaimer within. " Within where?  Huh
Re: Within...?
From the look of things, they've just stolen the forum description text from the PN forums - which do contain a disclaimer.
HSNetwork
Re: Within...?
The disclaimer stickied in the Classifieds forum lol.
Cheers for the pointer though, I have put one in place.
Regards,
Tom.
Buzzons
Re: Within...?
Toms a Noob, fact :p *attacks tom*
Fixes: 46
Re: Within...?
The sticky contains links to Forum Rules and Forum Guidelines that currently point to the Plusnet forum (where I have to login as guest).  These will need changing to make this forum self sufficient.
Regards, David
David
Re: Within...?
I have sorted the Rules link, and removed the guidelines link for now.
There is a lot of background work such as porting across the rules post to be done in the back ground, and PlusNet will still not guarantee that they will not wipe the beta database before this site goes live.
Chilly
Re: Within...?
Quote from: chillypenguin
No one has asked us that I recall (although it may have been a while ago!)
We will not be wiping the database.
Re: Within...?
Thanks Colin.
I did ask personally, and I believe you replayed but it was a very long time ago now, and the responce was that you did could not guarantee that the database would get wiped again.
Chilly
Re: Within...?
Ah, well, it's not happening now - there's too much in here Cheesy
