Netgear DG 814 router and ATA 1100 'phone adapter
fotobits
I have a Netgear DG814 (wired) router available and an ATA 1100 'phone adapter.
Both complete with all supplied power units, cables, adapters and documentation.
Details on the www.
I've reset both menus back to factory settings and can assist with the bespoke set up, as required.
The adapter works well, outgoing calls defaulting to the SIP connection.  Pressing a button on the adapter connects to PSTN.  Incoming calls, both SIP and PSTN.  Defaults to PSTN in the event of power, or other failures.
I replaced the adapter, because I required to be able to select a SIP or PSTN connection at the handset of each of my domestic 'phones.
I took the opportunity to replace the router at the same time, in anticipation of adsl 2 (!)
Reasonable offers, plus P&P.  I think P&P will be £5.50, insured.
Regards........Noel
