Epson Multimedia Mobile Projector
holdtight
Digital multimedia LCD projector, model: Epson EMP-53
I bought this on a whim just two years ago at the then retail price of £2999 and have used it probably no more than seven or eight times for short periods
its in very good condition and comes with its carry bag all leads instructions CD and CC sized remote control
Some pasted blurb from Epson:
Perfect for business educational and home uses alike the EPSON EMP-53 gives very bright 1700 ANSI lumens.
Featuring the newly-developed EPSON 0.7” Dream 3 LCD panels which boast a vastly improved aperture ratio, projections
are extremely bright and have unrivalled resolution
• High Bright 1700 ANSI lumens Mobile Projector
• Stylish, Compact and Lightweight – weighing just 2.9kg
• True SVGA/XGA digital Projector, supporting VGA to SXGA/UXGA resolutions, native VGA 800x600 max UXGA 1280x1024
• Silent Operation Mode
• Automatic Keystone Adjustment
• Monitor Output Connection
• 6 presentation Colour Modes for optimum
image clarity
• Self-storing Card-type Remote Control
• USB support
Projection Distance: 3ft. ~ 34.4ft. (0.91m ~ 10.49m)
Projection Mode: Front, Rear, Ceiling
Projection Screen Size: (Diagonal) 30in. ~ 300in. (76.2cm ~ 762cm)
Video Compatibility: NTSC, NTSC 4.43, PAL, PAL-M, PAL-N, PAL 60, SECAM
Projection Lens: F = 1.7 ~ 1.87 f = 21.3 ~ 25.6mm
Number of Colours: 16.7 Million Colors
Dimensions: (WxHxD) 12.4in. x 3.8in. x 9.4in. (31.5cm x 9.65cm x 23.88cm)
Cutting-edge Technology
Designed specifically to get the best possible the EPSON EMP-53 is packed with features to take care of all the little details and let you get on with the important stuff. There’s no timely set-up procedure, just place on the table plug in and turn on, and Auto Keystone Correction automatically adjusts the four screen corners to right angles no slants, no funny angles, no worries.
What’s more, the projector will detect whatever input source you are using automatically. Just plug in, switch on and they adjust the settings to suit.
With an incredible short cool down time of around 20 seconds, your ready to go without any hassles.
With so many great features, it’s amazing the EPSON EMP-53 is so lightweight and compact – weighing just2.9kg. It also offers great connectivity via the comprehensive interfaces. Monitor output is perfect when projecting from a long distance or need multiple screens.
However, if you’re very close to the screen you needn’t worry either as the EMP-53 can handle a 60 inch screen from just 1.8m.
http://www.hold-tight.co.uk/Bits%20&%20Bobs/Epson%20EMP-53%201.jpg
http://www.hold-tight.co.uk/Bits%20&%20Bobs/Epson%20EMP-53%202%20copy.jpg
http://www.hold-tight.co.uk/Bits%20&%20Bobs/Epson%20EMP-53%203.jpg
http://www.hold-tight.co.uk/Bits%20&%20Bobs/Epson%20EMP-53%204.jpg
Offers around the very reluctant £200 - 250 mark
