Beach tent
Beach tent
Just near the end of this summer!!! when it got quite warm and dry!!! I purchased online a "beach tent" this is an igloo type tent, very light weight that fits together with internal thin collapsible rods. These are often used as an alternative to a beach brolly to escape the sun and provide a bit of shade.
Trouble is, the one I purchased is too big for two people at 3.5m, it came from Amazon for £8.99 (called Monodome)
If anybody can use this, and fancies buying the smaller 210x120x210cm version from Amazon at £6.99 perhaps we can do a straight swap?
Mine is still in it's delivery packing unopened.
Check out the Amazon website for details under "beach tents"
1 REPLY
Re: Beach tent
Item disposed of...
