Wanted! Plastic stand to hold a Netgear router
fotobits
Netgear routers are supplied with a simple plastic stand to enable the router to be positioned vertically instead of lying flat on the desk.
I've lost the stand that came with my DG814 and would purchase one if anyone doesn't use their's.
Regards and thanks...Noel
wisty
My 834G V1 didn't come with one. I use a clear plastic box (the one's my chinese takeaway supplies). Upside down with a slot cut in it. Works fine.
fotobits
Many thanks for the tip, Wisty.
I appreciate you taking the trouble to reply.
Regards......Noel
