Solwise SAR715 ADSL Modem Router (4 ports) - As NEW
nxt201
Max ADSL Supported.
Comes with all original contents (PSU, 1m Patch Cable, softwares & manual can be downloaded at www.solwise.co.uk).
All boxed and 100% working, fully tested.
Pictures - www.peblv6.plus.com/SolwiseSAR715.rar
£20 + £8.50 (P&P)
MysteryFCM
Is it this one?, and if so, is it the wired or wireless version?
http://www.solwise.co.uk/adsl-sar715.htm
nxt201
Hi, thx you for your question. It's SAR715 and not '+' model, but both models are the same except the '+' model has PCMCIA slot at the front. thx
SAR715 is wired.
