PC's Built to spec and order
TPC's
Hi all,
Just joined the plusnet network and awaiting to be granted broadband.
Just to let you know (although I am sure most of you out there already do yourselves) I build PC's to order and to spec (depending on my suppliers stock)
I also upgrade fix and supply components for computers.
I will hopefully have a website running soon although it will not have anything major on it besides a couple of suggested systems (once again this is due to my suppliers stock levels and the change in the market)
If your interested or just want a part then drop me a line.
All the best. Cheesy
