Now sold ! please lock
holdtight
For sale as above gigabit server adapter with a low profile bracket this is brand new boxed and still shrink wrapped, now an unneeded item i would like to recoup some of the money i spent on it so any sensible offers considered
Those in the know or those that are likely to use it will know what it would cost to buy this
There is a picture Here and here`s some of the blurb from the spec sheet:
High network performance and flexibility via PCI-X bus at 64 bit/133 MHz
Alleviate server bottlenecks while increasing uptime through advanced server features
Designed to help alleviate bottlenecks wherever you need extra bandwidth, the Intel® PRO/1000 XT Server Adapter can also be installed now to accommodate future growth. Intel server adapters are designed to sense when the infrastructure has been upgraded and automatically begin running at Gigabit speeds. This easy-to-scale network bandwidth uses standard cabling, eliminating the added expense of installing new wire.
* Adapter Features: Intel® SingleDriver™ technology
* 10Base-T, 100Base-TX, 1000Base-T
* Cat-5, 4 pair; RJ-45
* Standard Plug and Play Specification Support
* Easy installation, Intel® PROSet II Utility
* Auto-negotiation, full-duplex capable
* Bus Type: PCI 2.2, PCI-X 1.0
* Bus Speed: 32/66, 64/66, 64/100, 64/133
Network Management:
* Wired for Management Baseline v2.0
* DMI 2.0, WMI & SNMP-manageable
* Offline Diagnostics
* Intel® Boot Agent
* ACPI Power Management
* Wake on LAN
Software:
* NOS Software Supported: Microsoft® Windows® 2000/XP/NT 4.0, DOS and DOSODI, Novell Netware 4.11, 4.2, & 5.x, SunSoft Solaris 2.6, 7 & 8, UnixWare 7.x, OpenUNIX 8, Linux 2.2.5 or later
* Advanced Software: Adapter fault tolerance, Adaptive load balancing, Fast EtherChannel, Gigabit EtherChannel, Intel® Link Aggregation, PCI HotPlug, and Active PCI
Technical Features:
* Data Rate Supported Per Port: 10, 100 & 1000Mbps
* Integrated Memory: 64KB
* Interrupt Levels: INTA
* IEEE Support: 802.2 & 802.3ab
* Data Path Width: 32-bit and 64-bit PCI-X
* Hardware Certifications: FCC B, CE, BSMI B, VCCI B
* Data Transfer Mode: Bus-master DMA
* Platform PC
* Warranty Lifetime
holdtight
Now sold ! any mods please lock
