ATA VOIP Adapter Wanted
I am after a VOIP Ethernet adapter, which will work with +Talk and enable me to plug in a standard DECT phone...
It needs to be cheap
Try www.aria.co.uk (No affiliation to them) my old man brought one from them last week for about a tenner +P&P, he says it works ok, can also be used with skype.
Stock code is TEL-E-ZI-PHONEBO but price is now £17 (they have specials on all teh time)
LiamM
That's a USB one. Metinks the OP wants one for a router so you do not need the computer to be switched on.
Oops, Missed the Ethernet bit, still for that price might be worth making an exception.
Hey,
Erm the only thing I could find very quickly was this.
I think its a little pricy to say the least, but it does allow for both a normal phone to be used as a sip phone as well as using your system.
Hope its of some help :/
Regards,
You can get those ones on Ebay for about £38, I had a Grandstream phone at one point, but it went faulty, it may just be that I had a friday afternoon one, but Grandstreams tech support is pretty dia!!
voip stuff
have you seen these ?
http://www.broadbandstuff.co.uk/product_info.php?products_id=370&osCsid=6f3e7e36af7467d18c8c74cf48ad...
available from various places, if you see them much cheaper then check that they are not tied to a voip service, they also sell them with vonage at half price but then you can't use them with anything else.
I would be interested if you find any alternatives.
