AMD A64 3200 Winchester Socket 939 does 2.7Ghz
Click here for image
300x9 = 2.7ghz @1.6vcore
Retail Chip, sold boxed with heatsink, fan, and AMD Booklet
Only reason for sale is that I've been offered an FX55
£140 including delivery gets you this fantastic clocking chip Cheesy
Please contact me via this thread or at james@firedragon.plus.com
Can provide feedback from another forum if necessary
[Moderators note by Thomas (kuglin): Image changed to link, as it was stretching the forums somewhat.]
^Thankyou, Image rechanged to a thumbail, if this is a problem just re-remove Smiley
Hi was the chip stable at this speed? also was it manualy overclocked? Shocked
The chip was manually overclocked by using the bios.
Here is a pic of it superpi and sandra stable:
Brickinit
not sure if i get this! same chip for sale from watford at £128.36 + p&p
^^^ Unless you wanted an overclockable chip, people pay more for a guaranteed stable overclock.
well watford electronics says Availability: 1-2 weeks
and if you add delivery, which I am including Total: £133.59
So 6.41 more for a chip that does 2.7ghz Cheesy
Brickinit
ah! the mist is clearing.i see you are taking the risk of overclocking the chip and if it goes pear shaped you loose the chip and have to absorb the cost.
Beauty of it is, these AMD 64's are peanuts compared to their P4 counterparts. After reading this thread I thought "let's see what it can do", my 3200 is now running smoothly at 2.5ghz, no doubt it could go higher but I don't need the speed right now!
Brickinit
do you suffer from a hotter chip if you overclock them and if so will it have any adverce effect on it?
Overclocking usually increases CPU temps and the more you overclock the hotter it gets. Whether it will affect it depends on how high it goes. >60C then the life of the processor may be affected and hotter still it may stop functioning or damage it.
You can often get better cooling methods anyway using better heatsink/fans and use better thermal paste to reduce temps. Also using additional case fans can help dissapate heat from the box. So there are ways to compensate for the CPU getting hotter.
It's to be noted the standard temperature for AMD64 is in the mid 30's so you've got a very large margin before you hit 60 degrees; they are pretty much the most overclockable chip to date without special cooling thanks to AMD moving to the built on heat disperser.
Brickinit
well thanks all for all the enlightenment, i don't think i'll start overclocking just yet, knowing me i'll overcook it
Sold elsewhere. Delete or close if necessary
[Moderators note by Thomas (kuglin): Locked as requested.]
