yanky laptop
yanky laptop
anybody purchased a laptop/notebook in the usa - any problems - power - software etc. any advice appreciated. my son is working there over the summer and wants to use digital camera, send emails etc but is worried about using it in this country.
- mark
Phantom_Flan_Fl
RE: yanky laptop
Biggest prob could be the power, they're 110V, we're 240V.
Depends if the laptop can change voltage.
Patch
RE: yanky laptop
We have laptops we have bought in the UK and when we take them overseas we don't normally have any problems. The power adaptors on our Dell's work at both 110 and 240.
You will need a different modem lead to plug into the uk phone socket, but adaptors are cheap. As for software I'm not sure.
I would have thought one problem would be warranty repairs and support?
Patch
RE: yanky laptop
One way you could do it would just to replace the PSU inside the laptop this would probably be the easiest way to avoid any problems with over powering the laptop.
