xbox and conexant amx64 router/modem/switch
i tried connecting my xbox to one of the ports of the router/switch, physical connection is established since LEDs on both switch and router lit up, however the xbox live menu on the dashboard doesn't come up
anybody using xbox with this router and made it work? any XBL beta testers here?
what would be the settings needed in the router/switch to make it work
thanks a lot in advance!
1 REPLY
RE: xbox and conexant amx64 router/modem/switch
Hi
Hate to ask the obvious but have you installed the Xbox live software.
You can get it off unreal tournament disc or from the Xbox live pack.
