using java applet on my plusnet homepages
Hello! i need some advice
I am trying to use a java menu applet on my homepage that relies on knowing the url of the page it is on to work.
I am using the same applet on another webpage on UK2net servers and it works fine - when i try on my plusnet page it gives a URL error...
i am using the URL : http://www.doublethink.plus.com/sonictonic/menutest.htm
Does anyone know of a more direct way of addressing the homepages server that might work?
Matt
RE: using java applet on my plusnet homepages
It gives a licence error to me. Often shareware type of things wont let you run them from a website. They often have a diffrent applet for regged and un reged.
you could try using
http://www.doublethink.plus.com\sonictonic\menutest.htm
but the licence error sugests the wrong applet somewere
> Thanks
> Matt
> you could try using
> > Thanks
> > Matt
Thanks for the idea... i will try it...
It is strange that this applet works fine on my UK2.net webspace and not on the Plusnet space...
hmm.. any other ideas anyone?
Matt
> you could try using
> > Thanks
> > Matt
Matt
