uploading a PHP portal to FOL
I only once set up a PHP portal (for example PHP Nuke) and that was a personal NT server.
Where should I upload the whole portal to? I assume cgi.free-onlione.net as the PHP don't execute when uploaded to homepages.free-online.net.
Should the whole uncompressed portal be uploaded to cgi.free-onlione.net?
How do I access it? (meaning, where is the index page suppose to be? Should I put a index.html file in my homepages.free-online.net default folder which direct me to the index.php file in the CGI directory?)
Any help would be appreciated!
Cheers
1 REPLY
RE: uploading a PHP portal to FOL
i uploaded mine, to cgi.free-online.net uncompressed. Then click start, click run, type
telnet cgi.free-online.net
type username, and pswd.
then in the directory of that file type
tar -zxvf (whateverportal).tar.gz
i think put ur "" html/ "" file into the hompages.free-online.co.uk (it dose work, but i think i can cause secuity probelms??) don't really know, but once u have unziped the program, there should be a install "help" file!
Althoguh i had problem with my sql.. tell me if u had any, i would reccomend Geeklog system, if they wern't using a old SQL server!!!
