upload to domain name _help !!
Hi can anyone give me a little information
i have made a webpage and wanted to upload it to my co.uk domain but have ended up with it on my personal web address site-ive tried for a couple of days and still cant work out how to upload it to the correct site
im using cuteftp
Much apreciated if someone could give me the info i need
Regards
Paul
1 REPLY
RE: upload to domain name _help !!
> im using cuteftp
> Regards
> Paul
Paul
Best thing to do here is to create a new directory inside the htdocs folder. for example my domain is in a folder called hmrg standing for Heywood Model Railway Group.
Then upload all your files into this new folder.
Once you have don that you need to go to the "My Domain names" part of the portal and you can then get your domain name to point to the new folder.
Don't forget to have a index.html file in this new folder.
Having set all this up you will have to wait until the system refrehes itself which I think is usually overnight.
Hope this helps
Regards
http://www.hmrg.co.uk
