uk.co
uk.co
anybody out there got a uk.co address (or did have perhaps I should say)Sad There are 8000 of us somewhere??
Pam
RE: uk.co
> Pam
There are alot of people out thier that do.
as unfortuante as it is, hopefully people will learn from this lesson - if you are going to buy a domain, buy a real one.
Chris
espresso_mick
RE: uk.co
> as unfortuante as it is, hopefully people will learn from this lesson - if you are going to buy a domain, buy a real one.<
They were real, wern't they?
http://www.theregister.co.uk/content/6/29359.html
I actually hadn't heard of these domains but as the article on the above link says they may be back.
RE: uk.co
They are not a full top level domain, or even a proper second level.
In the same way you wouldn't call your username.plus.com subdomain an actual domain.
.co domains are of course proper, they are the country domains from Columbia.
Chris
RE: uk.co
>They were very real and worked very well with the search engines so I carnt see the problem with them not being propper
RE: uk.co
I know they worked, as does your plus.com domain, but you should always be dubious about things like that.
Why buy a .uk.co 'subdomain' when you can buy a proper co.uk, com, net which always looks more professional?
the fact of the problems they are having now should convince you otherwise.
Chris
RE: uk.co
If you had seen the marketing material on the .uk.co website, you would understand full well the potential of such a address.
Overall, DNS logs from two LANs I manage, show that .uk.co is users 0.51% more than the .cx TLD (and .cx is pretty common). And in that, around 70% are actual web-sites, leaving 30% as very viable targets for purchase.
.uk.co is no different to the .uk.com domains names.
Sombody has simply registered the name, and is selling sub-domains (though the .uk.co was a little different).
However, it must be said. You must know who is the maintainer of the TLD, and that they will gurentee access, before you consider it as a business possibility.
