types of modems help needed
KimT
I have just bought a wirless router hich takes a DSL modem that conect to the broadband modem through a WAN prot. My modem [supplied with my f9 package] is a USB modem
I gues that I will have to buy a new modem than is WAN rather than USB. Will this work with my Force 9 broadband?
or can you suggest any other work around so that I can wireless net work all my PCs
thanks
Kim
Confusion Confusion??
Hello again,
Your question is very confusing and its not clear to me what it is your trying to achieve here with all this?
I'm guessing but I wonder if what your aiming to achieve is connecting mutiple machines (home networking) and giving web access via ADSL and a router?? If this is right I fail to understand where the modem comes in??
It doesnt sound like you would need a modem but I might be wrong?? you'll have to enlighten me on that one?
Ivan
KimT
modem type
I have bought a router that doesnt have a built in modem so the picture is:
phone line into
modem into
router
My broadband modem connects using the usb, whilts the router wants a ethernet connection
I am guesing that all i need to do is change my modem for one that uses an ethernet rather than a usb connection.
however being a dummy I wanted to check because the router says it works with DSL/cable. I assume DSL means ADSL?
Replying
Hello Again,
Good morning, well in reply. I think what your miss understanding here is that you dont need both (I think?) Look at it this way.
Phone Line into router -> Router connected to a Cat5 cable (your own local home network,etc) -> Cable connects to your PC/Server via a network card, typically a 10/100 network card.
**This does away with the requirement for a modem.
**DSL = Digital Subscriber Line
**ADSL= Asymetric Digital Subscriber line (asymetric because the upload and download speeds are not the same as each other).
**Like why would you need a modem plus a router, use one or the other preferably the router. This would give you a permanent ADSL web conection to F9. Your router would require a fixed IP address (and preferably either NAT or firewalling switched on to give added protection agains hackers,etc.
**Why does your router also require a modem? this I dont understand at all.
Ivan
Kim,
if you have brought a router without a modem, then yes you will need to buy a ethernet DSL modem to plug into the routers WAN port, or take your current router back and buy one with a built in modem, 3Com do a really nice modem/router/firewall/accesspoint for about £100
hope that answers your question
Darren
