testdrivef9 Login
testdrivef9 Login
This is really a query for admin, but someone else may have already asked a similar question (although nothing came up on the search).
Basically I would like to be able to use the postcode finder tool and screen scrape the results. However this is only available once I've logged in. Naturally I don't want use my own username and password. So my question is am I (or indeed any F9 account holders) permitted to use the testdrivef9 account to access such tools (or is this the intended purpose anyway?).
Kind regards,
Franz.
testdrivef9 Login
I would imagine you could just use the testdrivef9 login, but it may be restricted to what it can do.
testdrivef9 Login
Well I have tried just logging in as testdrivef9 and the postcode finder worked without any problem.
I was more concerned that I might be "told off" if I did this in an application.
Thanks for you help,
Franz.
