signature
StanderBy
signature
Hi anyone tell me how to get the Plusnet logo in my signature, similar to the mods here on forums. I have been looking around for the code to no avail but i know it must be around here somewhere.
thanks in advance
SH
signature
Do you mean:
Which is a single image so no good for you as your not a forum administrator
[img]http://www.kuglin.plus.com/misc/PlusNetVispSig.gif[/img]
Or what I have:
plusnet
Just use the following code in your profile signature and I also suggest you make it clear your a customer not a mod or employee like I have.
[b][color=purple]plus[/color][i][color=orange]net[/color][/i][/b]
StanderBy
signature
Thank you Peter, just what i was looking for.
(1st test)
signature
Will your defraggle tutorial improve performance of SATA drives too?
signature
Excellent user guide, although we all knew that anyway.
If you number the discs with a permenant marker before you take them out theres never any risk of putting them back in the wrong order too. :p
signature
Where does this ball bearing go?
signature
I was suprised that all the graphics are kept on the colour part of the discs. Surely they should be kept in the graphics card?
signature
No only some are kept there due to the fact that there is limited memory on the graphics card. Most are kept on the disk and only sent to the card when needed. :lol:
signature
maybe they should keep all the pictures in the monitor then, theres lots of space with it being the biggest part of the computer and then you probably wouldnt need so many cables...
signature
I bent that trapped bit of disc over instead of cutting it off. It doesn't spin any more, but makes a buzzing noise and smells quite hot. Is this normal after a defraggle, and how often should it be done? Also i couldn't see any pictures on any of the discs at all, but i can see some on my wall.
signature
Ah, just rememembered, deleted all my images after getting PM for displaying oversize avatar Wink
signature
If you read through the other guides on that web page it does say your motherdisk can spin quite fast so it does suggest welding it down, that might help.
Chris
signature
On a more serious note, i am convinced that if some of our (computer shop) customers saw this, they would try it, then try and bring drive back under warranty!
signature
Nah !, I don't believe it.
Must go now tho', got to look for a gas leak with a naked flame.
StanderBy
signature
Ok having sorted out the logo (thanks again for that) is there a way of making this a link to my Referrals? Well it makes sense to me
Thnks in advance
